Old 30# Spool
/ Old 30# Spool #1
jake98
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
I have a 24 yo spool of .035. It's like a wire rack kind of spool, Lincoln, and I'm wondering if it can be run on a modern machine? Wind it onto a modern plastic spool??
/ Old 30# Spool #2
I think that the big machines, with external wire feeder still use those, I saw a spool just like the one you discribed, in a video of an esab welder.
/ Old 30# Spool #3
One thing that might cause problems is if the wire has picked up any rust over time. If it has, you might find it doesn't give a satisfactory weld. How much rust is hard to put a definitive number on especialy over the interweb but if it has rust and you have trouble with poor welds from it, that could be the reason.
Back when I had my first MIG I bought a 9# roll instead of the much more expensive 2# roll but couldn't physically fit it onto the machine so I built a set-up where I could use my lathe as a power source and rewind wire from the 9# roll onto a 2# roll spool.
/ Old 30# Spool #4
If the wire is clean, Burn it. If it is cored wire, Pitch it.
/ Old 30# Spool
It's nice and clean, still in the bag inside the box. It's copper coated, is that normal?
/ Old 30# Spool #6
Good to go, Use it up. Copper Coated is the norm.
2014 CPS STEP DECK (A67714)
2014 CPS STEP DECK...
2001 FREIGHTLINER FLD132 XL CLASSIC (A67714)
2001 FREIGHTLINER...
2025 Wolverine BC-13-72W 72in Brush Cutter Skid Steer Attachment (A66734)
2025 Wolverine...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2009 HEIL CRUDE PUP TRAILER (A67714)
2009 HEIL CRUDE...
CATERPILLAR H95-S HYD HAMMER (A65056)
CATERPILLAR H95-S...
