Oily rags
/ Oily rags #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
I've always been told bu various wood workers to soak your oily rags in water to prevent them from spontaneous combustion. But nobody ever told me what to do next.
I have about a dozen rags and 2 pair of disposable gloves, all soaked with Boiled Linseed Oil, soaking in 2 gallons of water. All this is in a tin bucket with a fairly tight lid.
Today is garbage-eve and I need to make room for more rags in the tin can.
Is it safe to toss the rags into the trash now that they have been soaking in water? What about the water? I don't think (?) I want to dump it down the floor drain, it dumps into the house sump pump. I don't thing (?) I want it going into my septic tank.
What is the smart thing to do?
/ Oily rags #2
All the official instructions are going to tell you to keep them in a fireproof container and then take them to a licensed hazardous disposal site. About 1% of us are actually going to do this.
I don't even bother with the water. I collect them in a metal container and when I'm done for the day, I burn them, either in a burn pit or my wood stove.
/ Oily rags #3
Perhaps just spread/lay the rags out on the driveway till morning? They usually only combust when all stacked together and where they can generate internal heat. As to the water, you can just use it to water the weeds you may not want on your drive or walkways...
Good luck and stay safe!
/ Oily rags #4
I usually drape mine around the edge of the trash can. Then throw them in when I take it out to the cul-de-sac.
Ralph
/ Oily rags #5
I have a wire basket that I put my stuff in; the basket remains outside where it eventually off gasses and dries out. After an appropriate time...read "whenever they dry out and I think about it" I put the stuff in the garbage. Fortunately, I never use Linseed oil.
/ Oily rags #6
Totally agree. Just burn them in a metal bucket.
/ Oily rags #7
Yep in the summer in the burn pit, in the winter wood stove.
/ Oily rags #8
I don't want them hot in a can, so I hang them in the open air until they are dry, then into the garbage. It is the drying process that creates heat.
Bruce
/ Oily rags #9
I wrap them inside a plastic fertilizer bag and set them beside the burn pile which is inside a cool, damp part of the back hedge. They will be handy when the pile is ready to burn.
/ Oily rags #10
Yep, cheap fire starters:thumbsup:
/ Oily rags #11
Have seen several instances of smoldering/hot oily rags but have never seen them combust. Mostly back in the days of oil based paints and old fashioned turpentine. Would always leave mine to dry spread out in the sun away from buildings, then dispose of. They can burst into flames and cause serious issues. Only thing more dangerous is folks that leave fireplace ashes/coals on their decks. Have had three fires here in the past two years as a result. One resulted in major damage, required a major rebuild.
Q
/ Oily rags #12
Q
Back in the old days when I used to paint houses for a living, and when we used mostly oil-based paints, I can recall several times in my career when I absent mindedly stuck a rag soaked with paint thinner in my hip pocket. Not only can they burst into flames, the can set your butt on fire, in a manner of speaking.
/ Oily rags #13
Been there, done that too. That'll burn your buns....probably do it again sometime.:duh:
/ Oily rags #14
I throw any solvent or paint soaked rags out on the lower gravel driveway. If windy I throw a rock on top of them. When they dry out, I either burn them or throw them in the trash if they look dry enough. I don't bother with storage cans or water soaking them. Even if they did catch fire on the gravel, it would be no big deal. As for the linseed oil/water mix, I would just throw that on the the weeds in the fencerow.
/ Oily rags
I still have them.
So, am I hearing everyone correctly? I still need to dry them out before giving them to the trash man?
/ Oily rags #16
I still have them.
I would dry them. I don't know if soaking in water will inactivate the oil, or if the water will evaporate, then the oil will still be liquid and can generate heat as it oxidizes. Why take a risk on setting the trash truck on fire?
Bruce
Trash truck fires
/ Oily rags #17
I still have them.
i would dry them out first. Chances are that you have removed a lot of the oil from them and that oil is now in your oil/water mix, but I would still dry them out by spreading them out on some non flammable surface (like my gravel drive) until they are dry, then trash them or burn them.
/ Oily rags
Okay, that's what i'll do.
And next time I will skip the water part. Actually, that is what I have always done but with small jobs and one at a time, it was no big deal to lay them out to dry inside the garage. It's windy enough here that I will almost need a pile of rocks to hold them down if I put them outside.
/ Oily rags #19
I put my greasiest, oiliest rags in a capped plastic container of used motor oil and diesel. Make great fire starters.
