Oil & Fuel Oil
   / Oil #1
Obcop43
Del Rio, Tx
Massey Ferguson TO-35
Hello, does anyone know how to make sure I don't over fill trans/gear fluid on my TO35 model, thanks
I read something about removing some screws?
   / Oil #2
One way is to find the oil capacity in the owners manual and after draining completey, only put in the specified ammount. I believe you should just have fluid coming out of the lowest bolt hole on the right side access plate when the oil level is correcct. And then there is the dipstick in the same access plate.Fill it about 90% and wait a few hours for the fluid to get into all theee sumps and then top off. DO NOT use gear oil. Use only UTF or GL-1 transhydraulic fluid.
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
Poly Bristle Sweep, 78" x 8" (A59076)
Poly Bristle...
10222 (A56858)
10222 (A56858)
