Oil temp guage on HST models ?
   / Oil temp guage on HST models ? #21
On my 5240 I would add the sensor to the piping just before the cooler.
   / Oil temp guage on HST models ? #22
Best place is the transmission housing which is the hydraulic reservoir. You really want the temperature at the pump inlet - the pumps are the critical points. Oil entering the cooler will be the hottest if the system is designed right. What the hydraulic component suppliers are really looking for is the pump inlet temperature.
   / Oil temp guage on HST models ? #23
The output of the cooler would be easy then. If I remember right, on my L the lines that connect to the cooler have a piece of rubber line that could adapt a T fitting in for the thermocouple.
   / Oil temp guage on HST models ? #24
There is an oil cooler in front of the lower 6-8 inches of the radiator on my L4240. I keep an eye on it because it can become clogged with chaff.
   / Oil temp guage on HST models ? #25
echo that. My L4600HST was getting much hotter than I'd ever seen it on the gauge in the past. I hadn't been paying close enough attention to how much crap there was in the radiator behind the screen and the back side of the oil cooler. As soon as I blew that out front and back with air, the temp dropped to 1/4 of the gauge and stayed there even after an hour of bushogging.
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
2017 FORD F550 CAB & CHASSIS (INOPERABLE) (A58214)
2017 FORD F550 CAB...
2015 Ford Explorer AWD SUV (A56859)
2015 Ford Explorer...
2008 Kenworth T800 Semi Tractor, VIN: 1NKDX4TX68R235070, Day Cab, Cummins ISX-600 Turbo Diesel (A59076)
2008 Kenworth T800...
2007 Ammbusher DL66 Hydraulic 66in Brush Cutter Skid Steer Attachment (A55973)
2007 Ammbusher...
12V Diesel Fuel Transfer Pump (New/Unused) (A59225)
12V Diesel Fuel...
