Oil temp guage on HST models ?
/ Oil temp guage on HST models ? #1
Rmart30
Platinum Member
Alabama
Currently have Kubota L4600HST, Kubota M7040, Kubota M8540, two Massey 265's, Massey 230, ...... Had Long 510, Mahindra 3510.Ford 4000, Deere 4230.
I thought about this this weekend while using my 4600 ripping up some foodplots and could tell the hydraulics were very hot for a 75* day.
Do any of the Kubota HST models come with a guage or overheat warning light for the hydraulics ? If not has anyone installed one? Most of the construction equipment I work on has either a guage or light for hydraulic temp. It shouldnt be too hard to install one.
/ Oil temp guage on HST models ? #2
Edit !
A gauge might be fun to watch, but probably won't give much information you would act on. The larger HST dissipates its heat to the 8-9 gal volume of SUDT in the gear cases and circulates that through a cooler. Short of a broken cooler line, there's not a failure mode that a gauge would monitor. The oil temperature probably varies over quite a range depending on exact location, so a single temperature gauge wouldn't give much of a picture of what's going on.
A car's automatic transmission oil circulates to the engine's radiator for cooling - and that's already up near 200!
HSTs do get warm - but they usually stay within the design range, unless there's some problem for which temperature is just a symptom, not a cause.
Edit: Refund line forms on the left - Dick B
/ Oil temp guage on HST models ? #3
I drove my BX about 5 miles on Saturday, full throttle, pedal locked as fast as she would go. I noticed quite a bit of warm air coming up through the lever slots and around the seat. I was surprised that it was warmer there than any time I had been using the bucket the previous 3 hours and I was working it pretty hard for that. I would have been interested in knowing how warm it got.
/ Oil temp guage on HST models ? #4
A gauge might be fun to watch, but probably won't give much information you would act on. The larger HST dissipates its heat to the 8-9 gal volume of SUDT in the gear cases. Cooling depends on circulation, thermal mass and cooling of the tractor chassis by the air around it.
Unlike the smaller units, the larger HST has no fan or external oil cooler - so it doesn't have a failure mode that a gauge would monitor. The oil temperature probably varies over quite a range depending on exact location, so a single temperature gauge wouldn't give much of a picture of what's going on.
Hydraulic machinery is often ok with operating temps of 300-400 F. An example is a car's automatic transmission - they often circulate their oil out to the engine's radiator for cooling - and that's already up near 200!
HSTs do get warm - but they usually stay within the design range, unless there's some problem for which temperature is just a symptom, not a cause. As always, prompt cheerful refund if info is bogus. Dick B
In reality every Kubota above the BX has an external air to oil cooler. And no hydraulic machinery will run very long at 400*F. Damage starts to occur over 200*F.
/ Oil temp guage on HST models ? #5
Edit: I've had 9 L-series kubotas - the L48 and L5450's have coolers - the other 6 have no coolers for hydraulic oil.
/ Oil temp guage on HST models ? #6
I've had 9 L-series kubotas - no external oil coolers on any of them, unless you are counting the outside of the iron housings as the heat exchange surface.
Dick,
Are you sure there's not a line running to a steel tube that runs back and forth (side to side) in front of the radiator, but perhaps behind the debris screen ?
My Kubota B2910 has one ...
And if damage starts above 200 F what explains the millions of transmission cooler coils inside the water radiators of cars & trucks?
Coolant temps are (generally) held to just under 200 degrees ...
The higher the temp, the quicker the damage occurs.
The ATRA (Automatic Transmission Rebuilders Association) says that heat-related damage could be eliminated if fluid temps were held to 175 degree and under ...
/ Oil temp guage on HST models ? #7
My L3400 has an oil cooler in front near the radiator. I can touch the top of the transmission case from the seat. That is my gauge. It gets fairly warm, but if it was too hot to touch I'd get concerned.
/ Oil temp guage on HST models ? #8
See edited post above about 3 L's with coolers, 6 without.
Point taken about transmission temps. But if manufacturers immerse their trans fluid heat exchangers in the end tanks of radiators, doesn't that suggest 200 degrees is an adequate cooling medium ? Is the margin really that small?
/ Oil temp guage on HST models ? #9
I pointed one of those infrared thermometers at the transmission housing of my BX after about an hour of mowing on a hot afternoon. It showed between 180 and 185 degrees depending on where I pointed it.
Most construction equipment of the hydrostatic design (dozers, trackhoes, manlifts,RTFL's, bobcats etc) always have a hyd temp gauge and will run in the mid to high 200's in temp with some into the low to mid 300* range on really hot summer days and heavy working.
Most of the sending units for the gauges or lights are inline in the return side of the system or in the sump/hyd tank and Ive never seen in 20+ years of working on all types of construction equipment one that had multiples to monitor it in different locations.
I want to be able to monitor mine to give a baseline of what it normally runs and to tell when I am working it a little too hard. I found out quickly that it runs much warmer doing dirt work than it does with a rotary cutter. I was surprised that a gauge, or even just a simple hi temp warning light did not come standard.
If I can find a suitable location for mounting a gauge I will go that route for about $80.
If no suitable place to mount a gauge I will install a dash light or a buzzer hidden in the dash after some checks with the temp finder to see what degree sender to use for it.
It will be a fun inexpensive little project to do after I get the skid plates done.
/ Oil temp guage on HST models ? #11
Search for "dipstick oil gauge" on Amazon. The price seems quite variable but you may find something that would work. You won't get a dash readout though.
/ Oil temp guage on HST models ? #12
Dick,
You should always use a disclaimer when putting this chart up. It is decades old and is not accurate for todays automatic transmission fluids.
/ Oil temp guage on HST models ? #13
Oil to water transmission coolers are placed in the return tank of the radiator. Water entering the radiator will be approaching 200 degrees, but after passing through the core, what enters the return tank will be much cooler.
Interesting chart... I would agree that oil heated much past 200 degrees is not good for the oil or automatic transmissions.
/ Oil temp guage on HST models ? #14
We spent many thousands of $$$$ replacing hydraulic motors last summer. I asked the rebuild shop what caused the failures and his first question was 'do you have a cooler'? My response was no and his response was heat caused the failures. I asked what is the max desirable operating temp and he said keep it under 180 F and better if kept at 140 F.
Yes heat is a killer of hydraulics including automatics. The redline on my Allison HD740 is 210 F.
/ Oil temp guage on HST models ? #15
/ Oil temp guage on HST models ? #16
My 2001 L3710 HST has an oil cooler, mounted right in front of the radiator, slightly off set to the left.
/ Oil temp guage on HST models ? #17
Just reading this, I wonder if a regular, $15 oil temperature gauge would work? Okay, maybe $20. Just finding a place to screw in a sending unit would be the hard part.
/ Oil temp guage on HST models ? #18
Operating a machine with hydraulic or transmission oil temps near 400 must be exciting because the flash point of Mobilfluid 424, one of the most common oils used by OEMs for their hydraulic fluid, is 388F (from their product data sheet).
Gear pumps are almost all rated for 185 degrees max and piston pumps and motors 230 degrees or less.
Quality synthetics will provide about 25 degree margin over straight mineral oil before it starts to quickly degrade. Still the important thing for piston pumps and motors is viscosity at the piston slippers. Mobilfluid 424 is 9.3 at 100 degrees C or 212 F and that is where you will start to see major problems.
/ Oil temp guage on HST models ? #19
I've thought about adding a gauge to mine mainly just for information (and I like extra gauges). There are so few hydro failures on these tractors though that I just can't see fluid temp being an issue. Anything over 120* is uncomfortable to touch, so just because the transmission case or filters are too hot to touch doesn't mean the fluid is overheated.
/ Oil temp guage on HST models ? #20
I doubt if I would ever work hard enough in warm weather for this to be an issue, but just curious, where might you install a 1/8th NPT sensor so that it would do some good? There are tons of gauges for sale, under $20, so adding one might make sense for some users? Engine oil sensors are easy, even with metric adapters, but I don't know about transmission cases...
