Oil temp guage on HST models ?
   / Oil temp guage on HST models ? #21
On my 5240 I would add the sensor to the piping just before the cooler.
   / Oil temp guage on HST models ? #22
Best place is the transmission housing which is the hydraulic reservoir. You really want the temperature at the pump inlet - the pumps are the critical points. Oil entering the cooler will be the hottest if the system is designed right. What the hydraulic component suppliers are really looking for is the pump inlet temperature.
   / Oil temp guage on HST models ? #23
The output of the cooler would be easy then. If I remember right, on my L the lines that connect to the cooler have a piece of rubber line that could adapt a T fitting in for the thermocouple.
   / Oil temp guage on HST models ? #24
There is an oil cooler in front of the lower 6-8 inches of the radiator on my L4240. I keep an eye on it because it can become clogged with chaff.
   / Oil temp guage on HST models ? #25
echo that. My L4600HST was getting much hotter than I'd ever seen it on the gauge in the past. I hadn't been paying close enough attention to how much crap there was in the radiator behind the screen and the back side of the oil cooler. As soon as I blew that out front and back with air, the temp dropped to 1/4 of the gauge and stayed there even after an hour of bushogging.
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
4 Unused Montreal ST205/75R15 Trailer Tires (A53421)
4 Unused Montreal...
Flat bed utility truck with inline 6Cy engine (A55315)
Flat bed utility...
2000 Sun Tracker Pontoon Boat (A54865)
2000 Sun Tracker...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
