Oil Recommendations?
/ Oil Recommendations? #1
Amfab
TX25
Overthinking I am sure, but, I have used Mobile1 In my cars for years. Is there any reason why 15-40 Mobile1 would not be a good choice for a hot climate in which I operate my TX25H?
Thanks in advance,
-Andrew
/ Oil Recommendations? #2
FWIW, I’m using Shell Rotella T4 15W-40 diesel.
/ Oil Recommendations? #3
You don't indicate where you are. "Hot Climate" is relative to geography and could mean 40*F or 120*F. :cool:
/ Oil Recommendations? #4
If it is a diesel engine then run diesel oil. I run Rotella T6 in my tractor and Cummins equipped Dodge. Mobile 1 or Delvac synthetic in my diesel car.
/ Oil Recommendations? #5
Not all Mobil 1 oils are rated for use in diesel engines. Be sure to use the correct one.
Ah, yes, it is 29°48' North, Baja California, Mexico. Average annual high: 93º, average low: 57º. I am very often operating in 95º–100º+ weather.
I did not know that. Thank you. I am new to diesels. So something like Mobil Delvac Extreme Motor Oil 15W40 Heavy Duty Diesel I suppose.
-Andrew
/ Oil Recommendations? #7
Well there you go. You're in the "chilly" region. Probably the ocean breezes you get there. You're north of me at 29*23'. :ROFLMAO:
Yes, Diesel oil typically caries an API C-something rating. Like CJ, CI and CK. There's more but those are the most common.
Deutz 4-Cylinder Air-Cooled Industrial Diesel Engine (A63689)
Deutz 4-Cylinder...
2014 Ford Expedition SUV (A64557)
2014 Ford...
90in. Work Bench (A65640)
90in. Work Bench...
2015 GMC Sierra Z71 (A62679)
2015 GMC Sierra...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
Landhonor 20-gallon Oil Collector Vehicle (A66408)
Landhonor...
