Oil Recommendations?
/ Oil Recommendations? #1
Amfab
Member
TX25
Overthinking I am sure, but, I have used Mobile1 In my cars for years. Is there any reason why 15-40 Mobile1 would not be a good choice for a hot climate in which I operate my TX25H?
Thanks in advance,
-Andrew
/ Oil Recommendations? #2
FWIW, I’m using Shell Rotella T4 15W-40 diesel.
/ Oil Recommendations? #3
You don't indicate where you are. "Hot Climate" is relative to geography and could mean 40*F or 120*F. :cool:
/ Oil Recommendations? #4
If it is a diesel engine then run diesel oil. I run Rotella T6 in my tractor and Cummins equipped Dodge. Mobile 1 or Delvac synthetic in my diesel car.
/ Oil Recommendations? #5
Not all Mobil 1 oils are rated for use in diesel engines. Be sure to use the correct one.
Ah, yes, it is 29°48' North, Baja California, Mexico. Average annual high: 93º, average low: 57º. I am very often operating in 95º–100º+ weather.
I did not know that. Thank you. I am new to diesels. So something like Mobil Delvac Extreme Motor Oil 15W40 Heavy Duty Diesel I suppose.
-Andrew
/ Oil Recommendations? #7
Well there you go. You're in the "chilly" region. Probably the ocean breezes you get there. You're north of me at 29*23'. :ROFLMAO:
Yes, Diesel oil typically caries an API C-something rating. Like CJ, CI and CK. There's more but those are the most common.
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
HEAVYEQUIPMENT TIRES (A65643)
HEAVYEQUIPMENT...
Aluminum Turtle (A65583)
Aluminum Turtle...
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
