Oil & Fuel oil pressure
/ oil pressure #1
robert421960
Rockholds Ky
2014 Kubota L3301
has there been any problems with the oil pump on these tractors
i own a farm pro 2425
my oil gague has been going from hi pressure to very low and sometimes none
could it be the gague?
is there an easy check to find out for sure?
Thanks
Robert
/ oil pressure #2
Get a test gauge and screw it into the block where the sender is and test . If it still fluctuates i would guess it's a sticking relief valve of a partially blocked oil filter that is making the bypass valve blow off , but it would be more likely to be a faulty gauge . A rule of thumb with oil pressure is 10psi initial and 10psi for every 1000rpm's there after ie. an engine that does 3000rpm should have 40psi to prevent metal too metal contact . I would not opperate it again if i were you until it was tested .
/ oil pressure
thanks guys i feel its a guage also but will check for sure and repoirt back
/ oil pressure #5
sunpro makes gauges for 9$.. and you can get an adapter kit for nother 4-5$.. I would DEFFINATELY like to see what my oil pressure was really doing.. etc.
soudnguy
Champion Vibratory Roller (A60462)
Champion Vibratory...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
Holly 12 Row Harrow (A64047)
Holly 12 Row...
2023 John Deere Z950R Zero Turn (A63116)
2023 John Deere...
Tree Boom Skid Steer Attachment (A61572)
Tree Boom Skid...
