Oil Pressure Switch On PT422
   / Oil Pressure Switch On PT422
This might answer some questions about indication of too much tilt. This might help.
   / Oil Pressure Switch On PT422 #12
Hello Gentleman,
This switch should be hooked up to the external LED light that should be mounted in the area of steering wheel, so that you know that engine has a low oil pressure. I'm not sure if PT is using this feature. IT IS NOT A LOW OIL SENSOR AND IT WILL NOT TURN OFF YOUR ENGINE!
Regards,
Jack Gawecki
Robin America, Inc.
Technical Support Dept.
800-277-6246
They did not use it on my 422 built about 4 years ago. The switch is there, but nothing is connected to the wire coming out of the end of the switch.
Bob Rip
2006 JCB  930 MAST FORKLIFT (A58216)
2006 JCB 930 MAST...
LOT: Torch Cart w/Gages, Hose, Torch Head (TANKS NOT INCLUDED) (A59076)
LOT: Torch Cart...
SUV (A59231)
SUV (A59231)
3pt 25' Disc Harrow (A57148)
3pt 25' Disc...
Giyi Pile Hammer (A57149)
Giyi Pile Hammer...
2017 Ford F-150 XLT (A57148)
2017 Ford F-150...
