Oil Pressure Switch On PT422
   / Oil Pressure Switch On PT422
This might answer some questions about indication of too much tilt. This might help.
   / Oil Pressure Switch On PT422 #12
Hello Gentleman,
This switch should be hooked up to the external LED light that should be mounted in the area of steering wheel, so that you know that engine has a low oil pressure. I'm not sure if PT is using this feature. IT IS NOT A LOW OIL SENSOR AND IT WILL NOT TURN OFF YOUR ENGINE!
Regards,
Jack Gawecki
Robin America, Inc.
Technical Support Dept.
800-277-6246
They did not use it on my 422 built about 4 years ago. The switch is there, but nothing is connected to the wire coming out of the end of the switch.
Bob Rip
Massey Ferguson 1010 (A55272)
Massey Ferguson...
Honda UTV (A56859)
Honda UTV (A56859)
2015 Toro Z Master 5000 Series 72in Zero Turn Commercial Mower (A56857)
2015 Toro Z Master...
2021 Kubota SVL75-2 (A57148)
2021 Kubota...
Bigfoot Plastic Baler (A57149)
Bigfoot Plastic...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
