Oil Pressure Switch On PT422
   / Oil Pressure Switch On PT422
This might answer some questions about indication of too much tilt. This might help.
   / Oil Pressure Switch On PT422 #12
Hello Gentleman,
This switch should be hooked up to the external LED light that should be mounted in the area of steering wheel, so that you know that engine has a low oil pressure. I'm not sure if PT is using this feature. IT IS NOT A LOW OIL SENSOR AND IT WILL NOT TURN OFF YOUR ENGINE!
Regards,
Jack Gawecki
Robin America, Inc.
Technical Support Dept.
800-277-6246
They did not use it on my 422 built about 4 years ago. The switch is there, but nothing is connected to the wire coming out of the end of the switch.
Bob Rip
New/Unused IRGC40 Mini Golf Cart (A57453)
New/Unused IRGC40...
2019 Ford F-350 (A55973)
2019 Ford F-350...
John Deere 6120M (A57148)
John Deere 6120M...
2020 Case 5550 Trident (A56438)
2020 Case 5550...
2008 Ford F650 XL Landscape Dump (A55272)
2008 Ford F650 XL...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
