Oil Pressure Problem?
/ Oil Pressure Problem? #1
ballaterach
Aberdeenshire,Scotland
Iseki TX1510
Learned people the Oil Pressure Warning Light on my TX1510 has started coming on at low revs just recently what would be your possible diagnosis......please not expensive!!!
/ Oil Pressure Problem? #2
The least expensive thing to do is remove the warning light sensor and put an oil pressure gauge in its place to see what's REALLY happening. You may just have a defective sensor. The gauge will tell you for sure whether the fix is expensive or cheap - it will not tell you the fix unless it is indeed just a failed sensor. It's a starting point.
Many thanks for your reply and my apologies for the delay in replying. Rather than spend cash we haven't got right now on a gauge as the tractor was due its annual oil/filter change I did that but also put a new connector on the sensor and touch wood the light no longer comes on at low revs but obviously time will tell.....
finally managed to check the oil pressure today with a pressure tester just now and its 'ranging' between 6.5 and 7 PSI......is that good bad or??
2009 International 4300 Box Truck 24' (A62613)
2009 International...
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A67148)
2012 INTERNATIONAL...
2026 SDLANCH SDLC1220 High-End Carport (A64194)
2026 SDLANCH...
2007 International 4300 S/A Dump Truck (A64556)
2007 International...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
