Oil Pressure Problem
   / Oil Pressure Problem #1
2729rdr
SA250 Lincoln Welder Diesel
Hi Neighbors--My first try on this site..
I have a SA 250 Lincoln welder with a 152 Perkins that is blowing oil out of the dipstick tube. The gauge shows 70 lbs. of oil pressure, which seems high to me.
I just got this machine, which has been setting up for probable 2 years in a barn. I have done extensive work on the welder , which now welds like a dream. Now I have to address the engine problem. The engine starts instantly, and runs very quitely, with no odd noises. Could this possibly be the pressure valve in the oil pump? Thanks for any thoughts------Ray
   / Oil Pressure Problem #3
Oil pressure is created by the tight tolerances of the rotating components and size of the spray nozzles, if equipped. I wouldn't be too concerned with the oil pressure. I would be more concerned with the crankcase pressure and oil level. Does your oil level get higher without adding oil? Are you getting any air coming out of your crankcase vent tube?
Frontier WR1008 - 8 Wheel Pull Type Hay Rake (A55218)
Frontier WR1008 -...
UNUSED DIGGIT 20'X30' METAL GARAGE CARPORT SHED (A54757)
UNUSED DIGGIT...
2012 BMW 328i Sedan (A53424)
2012 BMW 328i...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
UNUSED LANDHONOR LHR-CIA200 - 200# CAST IRON ANVIL (A54757)
UNUSED LANDHONOR...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
