Oil Pressure Problem
   / Oil Pressure Problem #1
2729rdr
SA250 Lincoln Welder Diesel
Hi Neighbors--My first try on this site..
I have a SA 250 Lincoln welder with a 152 Perkins that is blowing oil out of the dipstick tube. The gauge shows 70 lbs. of oil pressure, which seems high to me.
I just got this machine, which has been setting up for probable 2 years in a barn. I have done extensive work on the welder , which now welds like a dream. Now I have to address the engine problem. The engine starts instantly, and runs very quitely, with no odd noises. Could this possibly be the pressure valve in the oil pump? Thanks for any thoughts------Ray
   / Oil Pressure Problem #3
Oil pressure is created by the tight tolerances of the rotating components and size of the spray nozzles, if equipped. I wouldn't be too concerned with the oil pressure. I would be more concerned with the crankcase pressure and oil level. Does your oil level get higher without adding oil? Are you getting any air coming out of your crankcase vent tube?
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55218)
2003 International...
Deer Gates (A53424)
Deer Gates (A53424)
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
