Oil leaking from brake dust cover
   / Oil leaking from brake dust cover #11
This same oil is shared by the transmission, brake, shovel pump, etc...?
For Yanmars, this is generally true.
In English, 'loader' instead of 'shovel' is what is said, regarding tractors. Shovel would be a hand tool, or a large excavator.
Digo lo que puedo con mi cien palabras de Espanol! :)
   / Oil leaking from brake dust cover #13
ok thanks California, sorry for my bad english from google translate
:D:D:D
No worries! / ¡No problema!
If you edit your profile to include your location, it can help people help you better.
All the best, Peter
   / Oil leaking from brake dust cover #14
In the end, I bought the brake rod boots from this online store:
The stores you mentioned either don't ship to Europe (I'm from Spain) or their shipping costs are very high.
Another question I have arisen: when I removed the brake rod boots, 12 liters of oil came out.
Is this amount of oil spilling normal, or could it indicate a damaged internal seal?
I collected the oil in some jugs, but if I want to fill it with fresh oil,
What kind of oil should I refill?
Fredricks Equipment in Hartselle, Alabama ships internationally, but I’m not sure what the shipping would cost.
(256) 751-3555. www.FredricksEquipment.com
Contact Danny Speakman in the Parts Department for more information.
Email: danny.speakman@fredricksequipment.com
Can you tell me which transmission oil is recommended for changing it?
Should I also change the filter?
Do you know the filter model it has?
   / Oil leaking from brake dust cover #16
Your 1610 does not have a screw on transmission filter. You do have a cleanable strainer, I believe found behind a triangle shaped flange down low on the left hand side of the transmission (setting in seat left) . Your fluid should be rated for transmission/hydraulic use. Such as john deere hygard. or equivalent
   / Oil leaking from brake dust cover #17
Did you verify what tractor model you have?
My tractor is a Yanmar 1610DT
   / Oil leaking from brake dust cover #20
Is it a power shift or geared transmission?
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
2007 Ford F-750 Chipper Truck (A52377)
2007 Ford F-750...
PORTA COOL FAN (A53843)
PORTA COOL FAN...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2015 PETERBILT 367 (A53843)
2015 PETERBILT 367...
