Oil- Hydraulic Filter Difference
/ Oil- Hydraulic Filter Difference #21
...wrong. I still have a few originals. After doing my recent fluid changes I did notice my oil and hydraulic looked and measured stangely identical although labelled different. Is there a fundamental difference or are they in fact the same...
The chinese filter is using "pinyin" abbreviation
YX:the "Y" means 液(yè) 压 -hydraulic
JX: the "J" means 机(jī) 油 -motor oil
the "original" manufacturer in the photo
YX0811A: http://www.bbfilter.com/
JY0811A: http://www.dycsjx.com/
YX0811A: ???????????
JY0811A: ???????????
Hi ,
Excellent info and link. Thanks for the input.
Dave
/ Oil- Hydraulic Filter Difference #23
I have been looking back through some old threads on a replacement for my chinese backhoe which uses a BB Bengbu Jinwei YX0811A hydraulic oil filter. All the distributors stateside are out of stock, so I started a search for a replacement. I have bought and tested two that cross referenced over to a replacement. First being the Baldwin BT839-10 which someone earlier had mentioned and the Fram P1653A which is more readily available around my area. I did try a Hastings filter HF731, which was supposed to also cross reference over, but found it did not match the threads of the filter housing. I have a PDF file of many other brands that cross over to the Chinese filter, but can not figure how to attach it.
/ Oil- Hydraulic Filter Difference #25
YX0811A is a hydraulic oil filter which is what my backhoe was shipped with. The JX0811A is a standard oil filter.
/ Oil- Hydraulic Filter Difference #27
May I weigh in?
The only difference between the two filters is the micron rating and the by-pass relief setting. Hydraulic return line filters usually have a nominal micron rating of 5µ to 10µ with a 2 to 5 psig by-pass. Engine oil filters usually have a nominal 15µ to 25µ rating with a 10 to 15 psig by-pass. That said, a human hair is about 60µ.
As far as I'm concerned, they are interchangeable.
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A61307)
Adams Load Out...
Giyi NWS38 Non-Connected Wood Splitter (A60463)
Giyi NWS38...
2008 HINO 268 4X2 26FT NON CDL BOX TRUCK (A59906)
2008 HINO 268 4X2...
2007 Range Rover Sport AWD SUV (A59231)
2007 Range Rover...
2004 Bulter Pole Trailer (A60352)
2004 Bulter Pole...
John Deere 4510 (A53317)
John Deere 4510...
