Oil- Hydraulic Filter Difference
/ Oil- Hydraulic Filter Difference #21
...wrong. I still have a few originals. After doing my recent fluid changes I did notice my oil and hydraulic looked and measured stangely identical although labelled different. Is there a fundamental difference or are they in fact the same...
The chinese filter is using "pinyin" abbreviation
YX:the "Y" means 液(yè) 压 -hydraulic
JX: the "J" means 机(jī) 油 -motor oil
the "original" manufacturer in the photo
YX0811A: http://www.bbfilter.com/
JY0811A: http://www.dycsjx.com/
YX0811A: ???????????
JY0811A: ???????????
Hi ,
Excellent info and link. Thanks for the input.
Dave
/ Oil- Hydraulic Filter Difference #23
I have been looking back through some old threads on a replacement for my chinese backhoe which uses a BB Bengbu Jinwei YX0811A hydraulic oil filter. All the distributors stateside are out of stock, so I started a search for a replacement. I have bought and tested two that cross referenced over to a replacement. First being the Baldwin BT839-10 which someone earlier had mentioned and the Fram P1653A which is more readily available around my area. I did try a Hastings filter HF731, which was supposed to also cross reference over, but found it did not match the threads of the filter housing. I have a PDF file of many other brands that cross over to the Chinese filter, but can not figure how to attach it.
/ Oil- Hydraulic Filter Difference #25
YX0811A is a hydraulic oil filter which is what my backhoe was shipped with. The JX0811A is a standard oil filter.
/ Oil- Hydraulic Filter Difference #27
May I weigh in?
The only difference between the two filters is the micron rating and the by-pass relief setting. Hydraulic return line filters usually have a nominal micron rating of 5µ to 10µ with a 2 to 5 psig by-pass. Engine oil filters usually have a nominal 15µ to 25µ rating with a 10 to 15 psig by-pass. That said, a human hair is about 60µ.
As far as I'm concerned, they are interchangeable.
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
2005 INGERSOLL-RAND SD-116F TF  ROLLER (A69167)
2005...
2017 TRAILEZE TE80 HTS LOWBOY (A65057)
2017 TRAILEZE TE80...
2025 Mini Excavator Attachment Set (A66734)
2025 Mini...
PORTA POTTY (A68842)
CAT 824C GP Gear (A68134)
CAT 824C GP Gear...
