Oil & Fuel oil filter question-need help asap
/ oil filter question-need help asap #1
ymurf
Bronze Member
I am changing my oil and filter today in my 2003 farm pro 2425.it is the y385 25 hp engine.It came with replacement filters for the oil and fuel.The oil filter that came with it and all the info i see on here says it takes a jx0706p.which is what came with the tractor.But when i took the one off the tractor to change it it has jx0806? They look pretty much the same but i cant find any info doing a search for jx0806.Should i just go ahead and put the jx0706 on that came with it?Thats what the info online says to use but thats not what i just took off..Any help on this would be greatly appreciated.
/ oil filter question-need help asap #2
Well the specs for the Y385 say the 0706 filter is the correct one, so you should be fine in using it. I replaced mine with a domestic Napa Gold 1516 filter after using my spare filter during the breakin period..
Thanks for the replacement info.
2019 FORD F-250 4X2 PICK UP TRUCK (A59908)
2019 FORD F-250...
iDrive TDS-2010H...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 16ft. Big Tex 2.5 Ton T/A Utility Trailer (A60352)
2005 16ft. Big Tex...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
