Oil & Fuel oil filter question-need help asap
/ oil filter question-need help asap #1
ymurf
I am changing my oil and filter today in my 2003 farm pro 2425.it is the y385 25 hp engine.It came with replacement filters for the oil and fuel.The oil filter that came with it and all the info i see on here says it takes a jx0706p.which is what came with the tractor.But when i took the one off the tractor to change it it has jx0806? They look pretty much the same but i cant find any info doing a search for jx0806.Should i just go ahead and put the jx0706 on that came with it?Thats what the info online says to use but thats not what i just took off..Any help on this would be greatly appreciated.
/ oil filter question-need help asap #2
Well the specs for the Y385 say the 0706 filter is the correct one, so you should be fine in using it. I replaced mine with a domestic Napa Gold 1516 filter after using my spare filter during the breakin period..
Thanks for the replacement info.
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
2024 Blue Diamond Skid Steer Vibratory Roller (A63116)
2024 Blue Diamond...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59910)
2019 ISUZU NPR 4X2...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
