oil filter help?
/ oil filter help? #1
BadAssRX7
John Deere 820
ok im not gonna get a deere oil filter for 10$+ and the 820 isnt near so i could see any oil filter #'s. Does anybody know what oil filter will fit a 3 cyl diesel 820 deere? any aftermarket brand will do i can cross it over to any brand if i have a filter # other than jd's. Thanks
/ oil filter help? #2
Wix always has the best site IMO for looking up equipment filters.
Once you have the more common wix number, it is easier to convert to all the other makers of filters.
So try this WIX Filters : Filter Look-Up
/ oil filter help?
jd# T19044
wix# 51243
fram# ph20 or ph20a
cool so now im off to the parts store and then load up and head out to install the new seals on the inj. pump shaft and the pump. And hope this stops the fuel in the oil problem. then an oil change and new filters and see what we get :)
/ oil filter help? #4
Good luck with it, I am out of state so I couldn't help with the filter numbers. I have used a NAPA filter on occasion and the store has crossed the numbers over without issue including the fuel filters.
/ oil filter help? #5
As J D filters are designed specifically for ag applications with diesel engines, I would spend the money for the correct filter rather than rebuild my engine 2000 hours sooner.
/ oil filter help? #6
Since the post is about a month old, I would assume he has already changed the filters.
And just because he doesn't use a JD filter doesnt meant he is going to have engine trouble. NAPA, WIX, hastings, baldwin, etc probabally all make a filter far superior to a JD filter, If JD isn't having one of them make their filter.
JD does not make their own filters. They have someone else do it and just put their lable on it. So why pay the markup?????
/ oil filter help? #7
I am uncertain who makes the Deere filters. It is certainly not Deere. I have seen the engine tests. For severe duty, the Deere filters are superior. I would use napa or wix in my truck, but not my tractor. There's a fine line between thrifty and cheap.
/ oil filter help? #8
According to your info Baldwin # BT259 . I have been a Baldwin dealer for 15 years . My opinion stay with a name brand or o.e.m. don't let anyone sell you "will fit ,it screws on " I hope I helped you , good luck .
/ oil filter help? #9
I've seen a lot of baldwin filters in severe applications. I am always looking for alternate parts suppliers. What part of the country are you in?
/ oil filter help? #10
Old post, old rant. Althought I don't really believe that any major mfg's are just putting a label on filters. They will give a set of specs to a filter mfg and have them build or use existing filters depending on that list of requirements. Probably a moot point considering the tractor and the filter # have both been around for many many years.
/ oil filter help? #11
Well said.
90in. Work Bench (A65640)
90in. Work Bench...
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
VH4D Wisconsin Engine (A65640)
VH4D Wisconsin...
PAIR OF TRACTOR TIRES AND RIMS (A65643)
PAIR OF TRACTOR...
3 Bottom Plow (A62613)
