Oil Filter Frustration
/ Oil Filter Frustration #41
jinman said:
Greg, if your tractor is capable of doing what I am doing in the attachment and not sucking oil into the #1 and #2 cylinders, then a little oil above the full mark on the dipstick should not matter. If I could have gotten off the tractor to check the oil without sliding down, I imagine the dipstick would have read at least 3 quarts low with all the oil in the front of the pan. Don't think that didn't run through my mind while I was doing this. I kept my ears peeled for any unusual sound and my eyes open for any unusual smoke coming from the exhaust.
Working on a downslope
Now that's a downangle.. I'll bet that seat had teeth marks in it afterwards!!
Soundguy
/ Oil Filter Frustration #43
jinman said:
Small pipe wrench? Ho-Boy!:eek: If a pipe wrench to fit a filter is small, I'd love to see what you call a big one.;) :rolleyes:
The handle is short.. but the jaw opens wide enough to go around the filter. But I use the smaller filter because of the FEL mount.
/ Oil Filter Frustration #44
I've got a big ? 3' aluminum pipe wrench at work.. that thing is nice and bulky.. works great, and is alot lighter than the big iron one on the mechanics truck!!
soundguy
/ Oil Filter Frustration #45
After reading about TMAC's frustration with his oil filter, then someone respectfully questioning if he was turning it the right way, I'd like to share an incident with you'll;
I had removed the seats from my eighteen wheeler, to replace the worn carpet, with a new rubber floor mat. After removing the carpet, and the shift boot, there was a slightly larger floor plate that I also removed to access the transmission. I decided to replace a normally very hard to get to air operated splitter valve that shifted the tranny from low to high range through very small 1/16" (I think) air lines. When reattaching the air lines, one proved to be a real bugger. Laying on my large belly on the floor of the truck, I could turn the ferrel nut 1/4 turn, I then had to get under the truck, using a different wrench, was able to turn the ferrel nut another 1/4 turn. After what seemed like an hour of doing this, it still wasn't tight! I took a break, got to thinking about it, then realized that while laying on the floor of the truck, I would tighten it that 1/4 turn, then crawling under the truck, I had gotten disoriented, and would loosen it 1/4 turn. As angry and disgusted with myself as I was, I still couldn't help but to laugh.
/ Oil Filter Frustration #46
Droy:
Are you by chance related to me or just do as I do?:D :D
Mechanics use steel pipe wrenches cause they put snipes on them!:p
Droy that is a halarious example. I could see this happening to me as well. :D
2016 FORD F-550 XL SUPER DUTY UTILTY/SERVICE TRUCK (A59823)
2016 FORD F-550 XL...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
