Oil Filter Frustration
/ Oil Filter Frustration #41
jinman said:
Greg, if your tractor is capable of doing what I am doing in the attachment and not sucking oil into the #1 and #2 cylinders, then a little oil above the full mark on the dipstick should not matter. If I could have gotten off the tractor to check the oil without sliding down, I imagine the dipstick would have read at least 3 quarts low with all the oil in the front of the pan. Don't think that didn't run through my mind while I was doing this. I kept my ears peeled for any unusual sound and my eyes open for any unusual smoke coming from the exhaust.
Working on a downslope
Now that's a downangle.. I'll bet that seat had teeth marks in it afterwards!!
Soundguy
/ Oil Filter Frustration #43
jinman said:
Small pipe wrench? Ho-Boy!:eek: If a pipe wrench to fit a filter is small, I'd love to see what you call a big one.;) :rolleyes:
The handle is short.. but the jaw opens wide enough to go around the filter. But I use the smaller filter because of the FEL mount.
/ Oil Filter Frustration #44
I've got a big ? 3' aluminum pipe wrench at work.. that thing is nice and bulky.. works great, and is alot lighter than the big iron one on the mechanics truck!!
soundguy
/ Oil Filter Frustration #45
After reading about TMAC's frustration with his oil filter, then someone respectfully questioning if he was turning it the right way, I'd like to share an incident with you'll;
I had removed the seats from my eighteen wheeler, to replace the worn carpet, with a new rubber floor mat. After removing the carpet, and the shift boot, there was a slightly larger floor plate that I also removed to access the transmission. I decided to replace a normally very hard to get to air operated splitter valve that shifted the tranny from low to high range through very small 1/16" (I think) air lines. When reattaching the air lines, one proved to be a real bugger. Laying on my large belly on the floor of the truck, I could turn the ferrel nut 1/4 turn, I then had to get under the truck, using a different wrench, was able to turn the ferrel nut another 1/4 turn. After what seemed like an hour of doing this, it still wasn't tight! I took a break, got to thinking about it, then realized that while laying on the floor of the truck, I would tighten it that 1/4 turn, then crawling under the truck, I had gotten disoriented, and would loosen it 1/4 turn. As angry and disgusted with myself as I was, I still couldn't help but to laugh.
/ Oil Filter Frustration #46
Droy:
Are you by chance related to me or just do as I do?:D :D
Mechanics use steel pipe wrenches cause they put snipes on them!:p
Droy that is a halarious example. I could see this happening to me as well. :D
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
2014 Ford Focus Sedan (A59231)
2014 Ford Focus...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2015 Dodge Journey SXT SUV (A59231)
2015 Dodge Journey...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A59230)
2004 Pierce Tilt...
