groundcover
Veteran Member
This Thread sound like one on the Whale site! When the price of Diesel was going up every night I was goiing to run the Cummins on whale oil,America's first renewable resource !
yeah thats why i need to tear mine down , blowing oil i'd say out into crankcase . was little but 580 hours a quart a hour now .my yanmar 20 hp has 446 hours
started dripping a quart every 2 hrs or less out blow tube off valve cover
what is up with it ???
it's a 83 year model 4 wheel drive
i bought it used with 435 hours and it looks new
tube might have been plugged to sale ???
could this be the start of blowed head gasket ?
no oil in water or water in oil
it's hard to start now , but winter is on way so temps at night have dropped
no excessive smoke out exhaust , no bubbles in radiator .
how do you check compression ?
Before you get your shorts in a wad find a good plow and take it out in a field and try to pull the flukes off the plow for an hour or two. Bring it back and change the oil and filter. You may be pleasantly surprised.I have a Yanmar 1500D that has a very small amount of oil at the end of the blow by tube coming out of the crankcase vent housing. The only difference is that once it starts up and runs for about a minute there is white smoke coming from the tube also, and when you uinscrew the oil filler cap the same white smoke comes from there also. I have worked on several cars before, never diesel, and am wondering how long or difficult it would be to rebuild the rings....the engine was totally rebuilt last year and worked fine all spring and summer until about a month ago....never did overheat and I changed the oil and filter as scheduled. Should I rebuild again or get a match and look for a new tractor?
