Oil changing intervals question?
/ Oil changing intervals question? #1
BobcatTR
Decatur, IL.
Bobcat CT225
Ok, my manual says, perform at first 50 hrs, then as scheduled.
Done!
Then at 100hrs
Done!
Then at 200 hrs.
Done!
Next says 400hrs?????
I just changed at 290, thinking every 100 hrs.
So, actually the book shows.......
8-10,50,100,200,400,800,1000.
I'm confused????
Thanks for your help!
/ Oil changing intervals question? #2
I'd say you're doing fine.
Think in terms of the miles equivalent. The miles equivalent (e.g. like in a car or truck) would be if you multiply the hours by about an average of 50 mph. 200 hours would then be almost 10k miles. That's quite a lot.
I've skipped oil change this year. Did the 50 hour one and now only had about a 100 at the 1 year mark. Will wait until next year or when it shows about 150.
Ralph
/ Oil changing intervals question? #3
If 100 hrs works out to somewhere near once a year, I'd do it. Good quality time with your "baby":D and there's no such thing as too soon for clean oil & filter, may not be necessary but it won't hurt it:thumbsup:
Great advice! I'll go with that.
I change oil in mowers etc, once a year!
Cheaper than a NEW MOTOR!
Thanks for replies!
/ Oil changing intervals question? #5
I put hour meters in my pickups (now built in to many vehicles) and in my use, much to my surprise my average mph was in the 20's. I estimate I was 50/50 highway & local driving.
Thats really intetesting!
Never thought of looking at it that way!
That is a lot!
Thanks for sharing!
/ Oil changing intervals question? #7
I say 100 hrs or seasonal after break in.
/ Oil changing intervals question? #9
Lets keep in mind this is 2017 with unleaded gasoline and fuel injection or low sulfur diesel and common rail injection. It ain't 1970. There is not the unburned fuel containing fouling, abrasive or corrosive compounds entering the crankcase to contaminate the oil.
Very true! Now doing 5000, and even 10,000 mile oil changes!
Oil filter every time.
Times have changed, for the better, concerning environment, and performance!
Great point!
/ Oil changing intervals question? #11
Great point!
That is a lot of miles for a tractor.
Lol! Yes it is!
Sorry, should have said for new cars and trucks!
Sure wouldn't want to be on my tractor that long!
/ Oil changing intervals question? #13
I change the oil & filter on my tractor every 100 hours or every fall - which ever comes first. Been doing it that way for 35+ years and seems to be just fine for my equipment.
/ Oil changing intervals question? #14
Clean fluids and filters are the first line of defence for keeping your equipment running well for a long time.
100 hours or once a year, whichever comes first.
To comment on some previous posts, in 2017 we now have to deal with things like exhaust gas recirculation (egr) on our Diesel engines. This creates more soot, that gets past the rings and into the oil. This subsequently can cause sludging that can ruin your engine.
Thanks! News to me!
Very nice to know now.
/ Oil changing intervals question? #16
Go ahead, be stuck in the past. I'll bet those 100 hr oil changes have also prevent stampedes of wild elephants across your property.
/ Oil changing intervals question? #17
Thanks! News to me!
Some of the same exhaust that came out of those cylinders is being routed back in. How has this clean exhaust suddenly become dirty and harmful? btw if you want to boost the engine's thermal efficiency and fuel efficiency , a blocking plate across the EGR port will do wonders.
/ Oil changing intervals question? #18
I don't quite see your point buickanddeere but I've never seen elephants on my property and I'm somewhat partial to the maintenance schedule recommended in my Kubota operators manual.
/ Oil changing intervals question? #19
Why such a mean post?
/ Oil changing intervals question? #20
The egr reduces the burn temps in order to prevent the production of nitrous oxides (pollutant that causes ground level ozone) but also causes more soot. As a result it痴 then necessary to have a particulate filter (DPF) to collect the soot, which is also a pollutant. Then as the dpf plugs up, it痴 necessary to perform a regen, usually by far exhausting fuel into it or spraying directly into the dpf through a separate line. This burns the dpf clean restore exhaust flow.
So to answer your question, the egr causes the exhaust to become dirty.
The end result is, the life of the Diesel engine is significantly compromised and the pollution is released all at once instead of gradually during operation. Seems logical.
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
2013 VOLVO VNL 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2013 VOLVO VNL 6X4...
2015 Dodge Journey SXT SUV (A61574)
2015 Dodge Journey...
2025 Intersate Fabrique 12' x 6' Dump Trailer (A62613)
2025 Intersate...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
