Oil & Fuel Oil changes on 2210
/ Oil changes on 2210 #1
organ grinder
Other than removing the deck (which I do not want to do), does anyone have any experience in changing the oil on a 2210? There's not enough room for a tray or pan. The local dealer says he uses an old piece of rolled up cardboard to drain the oil to a pan, but I can't see keeping an oil-saturated piece of cardboard around. Thanks for any ideas or suggestions.
/ Oil changes on 2210 #2
Maybe you could sharpen the blades and grease the mower deck at the same time you change the oil?
On one machine a while back, I was able to thread a pipe nipple into the oil drain hole so that the oil would drain somewhere where I could put a container.
If you try this, make sure the threads match. If you have a drain plug with a square head, the threads are probably standard tapered IPT (Iron Pipe Threads). A threaded iron black pipe would probably fit that hole (as would a $$$ brass pipe nipple).
/ Oil changes on 2210 #3
Taking the MMM off takes 5 minutes...you will spend more time trying to deal with getting the waste oil contained than that IMHO:D
/ Oil changes on 2210 #4
I agree with KennyD. I have a 2305 and it takes less than 5 minutes to take the deck off. Two pins, disconnect the driveshaft, turn the wheels then take off the front mount and your done.
/ Oil changes on 2210 #5
Try aluminum oil. If you fold a sheet repeatedly upon it'self you can mold and shape it to fit around most anything. Then just scrunch it up upon itself when your done and throw it out.
/ Oil changes on 2210 #6
There's more pressure than you think when you open that plug. You're going to want some room to monkey that pan around to catch it! :)
/ Oil changes on 2210 #7
I tried an oil change once on my 2210 leaving the deck on but never again. Used a funnel attached to a hose. Ended up getting oil spilled on my gravel driveway that required about 30 minutes of cleanup time including time spent burning up the remaining oil with a propane torch that I wasn't able to remove by shovelling. Mike
/ Oil changes on 2210 #8
I'd spend the 5 minutes taking the deck off..... It'll save you 45minutes and countless oily "fire-hazzard" rags of clean up time! :rolleyes:
/ Oil changes on 2210 #9
Once you learn how to pull that deck, it will be easy.
D.
/ Oil changes on 2210 #10
The worst part is the oil runs right into and behind the front driveshaft boot if I remember back to my 2210 days. Its stupid, and I always used a piece of Vinyl siding to direct the oil out the side and into the drain pan.
/ Oil changes on 2210 #11
Try cutting out part of the side of a one gallon oil bottle -- jug, leave the cap on the bottle. This is easy to handle, and should hold the amount of oil that will drain out of your engine. Then empty that into your recycled oil container. (That's what I've seen the "professionals" do.)
L8R
/ Oil changes on 2210 #12
One other option would be go with a Femco oil drain valve ( title ) and then one of their angled drain tubes ( title )...
I have one on my Dodge Cummins and I love it.. Never had a problem with the valve leaking the dust cap coming off... I have been using since early 2002
Brian
Thanks to all for the good suggestions. I ended up getting a piece of plastic guttering at Home Depot, the kind that goes on the end of a downspout that flops down when it rains. It's long enough to reach my pan and is easy to handle. Works great.
/ Oil changes on 2210 #14
L8R
I just cut the side out of a gallon plastic oil or antifreeze jug. Works great for changing the BX23 oil with the mmm mower attached.
L . B .
2012 VOLVO VNL64T630 6X4 T/A  SLEEPER TRUCK TRACTOR (A59912)
2012 VOLVO...
Club Car (A59231)
Club Car (A59231)
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
John Deere 2840 Tractor (A64047)
John Deere 2840...
UNVERFERTH 12R30" RIP STRIPPER (A63291)
UNVERFERTH 12R30"...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
