oil change
/ oil change #1
Anonymous Poster
Epic Contributor
The sticker on my B7100hsd states 4 QTs of oil. The manual states 3.6 QTs. With one is right.
/ oil change #2
Otto1, If it was me I'd fill to 3.5 QT run for a short time then shut down. I would then allow time for oil to drain to the pan and check the dipstick. Slowly add oil until you reach the FULL MARK. This has always worked for me in the past, as stated oil capacities and info are sometimes vague and or incorrect.
/ oil change #3
Otto, banjobj does the same thing I do. Such discrepancies are not unusual. However, I can also tell you that when I had a B7100, it held 3.5 to 3.6 quarts. Your mileage may vary./w3tcompact/icons/wink.gif
Bird
/ oil change #4
otto1,
Like Bird said on a B7100 3.6 qts,but I found out on my B7100HST when changing the oil plus the filter its a tad over 3.6 US qts...could be the changing of the oil filter.
Hope your oil stick easier to get out than mine,always seem to hit a knuckle or two.
Thomas..NH /w3tcompact/icons/wink.gif
/ oil change
Thanks guys. It takes about 3.6qt to fill to the top of the dip stick with filter. In the auto buiss. I to have learned not to go by the dipstick alone.
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2016 Jeep Patriot Sport SUV. (A64557)
2016 Jeep Patriot...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
(APPROX. 450')LOT OF LATCH LOCK 6" IRRIGATION PIPE (A64278)
(APPROX. 450')LOT...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
New/Unused Landhonor LHR-CSC10 Squeeze Chute (A65583)
New/Unused...
