number two
Veteran Member
- Joined
- Apr 2, 2007
- Messages
- 1,423
- Location
- Northern Lower Michigan
- Tractor
- Kubota B3030HSDC Kubota L2501HST
I occasionally see B3030 owners wondering how to do a neater oil change.
The loader mount is directly under the oil pan drain plugs.
There are two access holes in the mount for socket clearance,but no way will the oil flow through them!
Enter the Form-a-Funnel.
It's a 6 1/2" x 14 1/2" flexible green sheet of metal reinforced vinyl like material.
I was able to shape it to direct the hot oil around the loader mount and into the drain pan.
When the first side drained,I slid it over and pulled the other drain plug.
Didn't work too bad,with minimal mess.
While not perfect,it was the neatest oil change yet on this tractor.
Hope someone finds this usefull.
Good Luck!
Good Luck!
