Oil change with Form-a-Funnel
   / Oil change with Form-a-Funnel #1
number two
Northern Lower Michigan
Kubota B3030HSDC Kubota L2501HST
I occasionally see B3030 owners wondering how to do a neater oil change.
The loader mount is directly under the oil pan drain plugs.
There are two access holes in the mount for socket clearance,but no way will the oil flow through them!
Enter the Form-a-Funnel.
It's a 6 1/2" x 14 1/2" flexible green sheet of metal reinforced vinyl like material.
I was able to shape it to direct the hot oil around the loader mount and into the drain pan.
When the first side drained,I slid it over and pulled the other drain plug.
Didn't work too bad,with minimal mess.
While not perfect,it was the neatest oil change yet on this tractor.
Hope someone finds this usefull.
Good Luck!
   / Oil change with Form-a-Funnel #2
I have a form a funnel, never used it yet.
   / Oil change with Form-a-Funnel #4
Never heard of it. I'll have to look that up.
Normally I just put a big drain pan under it and let it run. Then use a can of brake and parts cleaner to spray it off clean when I'm done.
   / Oil change with Form-a-Funnel #5
It's like vinyl coated lead sheeting. I have been wanting to try one for some time. I think they have different shapes and sizes too.
   / Oil change with Form-a-Funnel #7
form-a-funnel
   / Oil change with Form-a-Funnel #8
You can make one with a piece of aluminum flashing.
   / Oil change with Form-a-Funnel #9
Yep. Also, in a pinch, a sheet of heavy duty aluminum cooking foil, doubled or tripled over before forming.
   / Oil change with Form-a-Funnel #10
Yeah, thanks, I need to remember that trick. I have been doing the McGyver/cardboard/duct tape thingy as previously mentioned. Usually resulting in oil all over my hands. :)
1301 (A58374)
1301 (A58374)
3PT DRAG HARROW (A52708)
3PT DRAG HARROW...
2007 Yamaha Rhino 660 (A56435)
2007 Yamaha Rhino...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
