oil change mistake
/ oil change mistake #61
Been changing my own oil for over 50 years.
Here's a tip if you run into a filter that is on so tight that it seems like you're going to crush it before it loosens.
Instead of applying pressure to the wrench to the point of crushing the filter, just put hard pressure on the filter wrench and HOLD the pressure.
More often than not, the filter will finally begin to loosen.
/ oil change mistake #62
very well could be.. that small one just looks too small to me...
of course gm tells me my 5.3 buring 2.5 qts oil between changes is within spec too.. :(
soundguy
Yea i always laugh at GM and Ford i think GM more so that says untill its more than i think a Qt every 500 miles its not eccessive. I would agree really my ranger with 285K on it will only blow blue slightly if you rev way up sitting still or getting on it! No blue just tooling around, and therefore if crucing around less than 50mph you burn less than an interstate trip at 75mph.
/ oil change mistake #63
That is a very interesting tip. I hope I can remember to try that when the time comes.
/ oil change mistake #64
Also a big mistake I see so many make is they put the filter wrench at the end of the filter, not by the base. The base is where all the strength is.
I am not saying I do this every time but if I have one that is tough to get off I stop and re-think things. First thing I try is moving the wrench to the base area and 9 times out of 10 that does the trick.
In doing about 75 to 100 oil changes per year for the last 15 or so years and maybe 20 per year for 15 years prior to that I have yet had a filter that would not come off with a filter wrench and some patience.
Never had to stab a screwdriver, use a cold chisels, ect that I hear so many tell stories about.:confused2:
Chris
/ oil change mistake #65
yep... my 5.3 don't smoke at all.. but in 3500m it will suck 2.5 qts
and it's had good service. i never scrimped on oil or filters. etc. was like that from the beginning.
going to a 10w30 vs a 5w30 does curb it to 2qts though :(
soundguy
/ oil change mistake #66
We used to have motorhome that was powered by a 1991 Ford 460 cu. in. engine. If we stayed in one place for a month or two; i.e., didn't run the engine for a month or more, when we hit the road again, it would be a quart low on oil in 400 miles. And then it could go the other 2,600 miles to the 3,000 miles oil change with no more added to it.
/ oil change mistake #67
awe that's just the built in ring lubricator.. :)
Chris
It is extremely difficult to get a filter wrench to the base of the filter on my F150. I use motorcraft filters because I like the ribbed design on the end, makes for better grip. I put a wrench to it when putting the new filter on mainly because it is hard to tighten by hand. I snug it about 1/2-3/4 turn.
/ oil change mistake #70
The base may be the strongest area, but the top is next strongest; the middle will probably crush the easiest.
Are you using a fluted cap wrench on the top or a strap wrench?
My experience has been that certain vehcles just get very tight, maybe the oil or filter base gets real hot and does something to the gasket material that makes it stick or expand.
My GF had an MG that ran extremely hot under the hood and the filter would always be real tight even if you tightened it the minimum turns on installation. The only way I would get it off was with a 24" pipe wrench and you would pull so hard the engine would be rocking on the motor mounts.
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
2022 New Holland C327 Compact Track Loader (A61307)
2022 New Holland...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
