Oil Change Interval
/ Oil Change Interval #1
NewToy
Ohio
'05 Farmtrac 270DTC
My manual says to change the oil every 200 hours after the initial 50 hour service. That seems like alot of hours, or is it just me? I figure at 30mph that would be like 6,000 miles in my truck. I like to change it every 3,000 so I reckon I'll change the tractor every 100 hours. It will make me feel better. I always get that warm & fuzzy feeling after doing the complete service on the tractor.
John
John
/ Oil Change Interval #3
My tractor also recommends every 200 hrs. Mine will be changed in May & November irregardless of the manual. I've read too many reports on the breakdown of oil, particularly on high cycle (hot & cool) engines. I also am changing the hydraulic fluid on a yearly basis (Nov) because of the hygroscopic properties of hydraulic fluid, not to mention the quick breakdown of carbon chains in the oil in high shear (read gear pump) applications.
/ Oil Change Interval #4
/ Oil Change Interval #5
Nobody ever hurt nothing by changing oil too often and don't let some tree huggin hippy tell you it is a waste of oil. The old oil might still be good, but it is a drop in the bucket and you get some value from the new oil since you feel better about it.
I would rather replace good oil than to wait until the oil has broken down and begun to ruin my engine.
/ Oil Change Interval #6
/ Oil Change Interval #7
I change mine every 50hrs which is working out to about twice a year.
/ Oil Change Interval #8
/ Oil Change Interval #9
Kioti recommends every 100 hours for my CK20HST, but I change it every 50 hours because I use a high sulfer content diesel fuel. High sulfur = high sulfuric acid which can lead to cavitation in the engine.
Even if I didn't use high sulfer, I would probably change it at 50. The oil just isn't that costly, and I like taking good care of my engine.
John
/ Oil Change Interval #10
John
/ Oil Change Interval #11
My manual says 200 hours after the first 50. I change the engine oil (Mobil 1) at 100 hours, which is about once/year for me. The 200 hours on the hydraulic and gear oil is nothing, as I've typically gone over 100k on my car/pickup transmission oil (manual trans) changes; only change them when the seals start to sling a bit of oil. Oil change stops the slinging because new oil swells the seals again. Will follow the manual on this.
Ralph
/ Oil Change Interval #12
Ralph
/ Oil Change Interval #13
</font><font color="blue" class="small">( My manual says 200 hours after the first 50. I change the engine oil (Mobil 1) at 100 hours, which is about once/year for me. The 200 hours on the hydraulic and gear oil is nothing, as I've typically gone over 100k on my car/pickup transmission oil (manual trans) changes; only change them when the seals start to sling a bit of oil. Oil change stops the slinging because new oil swells the seals again. Will follow the manual on this.
Ralph )</font>
Do you use Mobil 1 in a diesel?
Bob
/ Oil Change Interval #14
Ralph )</font>
Bob
/ Oil Change Interval #15
Mobil 1 is diesel rated. I use it in my JD and my Benz diesels. Go 100 hours on the JD and about 6,000 miles (once/year) on the Benz.
Ralph
/ Oil Change Interval #16
Ralph
/ Oil Change Interval #17
</font><font color="blue" class="small">( My manual says to change the oil every 200 hours after the initial 50 hour service )</font>
My Nh manual says every hundred on the crankcase.. If I don't get 100.. it gets a service before I put it up for the winter. Now.. my tranny fluid says 200 hours.. etc.
Soundguy
/ Oil Change Interval #18
Soundguy
2008 Honda Civic Coupe (A64557)
2008 Honda Civic...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
Case IH 200 50' Field Cultivator (A66285)
Case IH 200 50'...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A65054)
1994 CHEVROLET...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
