Oil and Filter
/ Oil and Filter #1
timkins
Fishers, NY
Cub Cadet Model 2542
Just changed the oil and filter plus the transmission filter on a 20hp Kohler Cub model 2542. Its ridiculous what the dealer charges for 1 quart of hydrostatic transmission fluid. What I am looking for is cross reference numbers for the Oil Filter, Transmission Filter and transmission fluid for the 2542. Anybody that has the appropriate cross referenced numbers so I can go to a NAPA store would be appreciated.
/ Oil and Filter #3
An equivalent oil is 20W50. If you are using Drive System Plus synthetic oil, as I do, I use Mobil 1 20W50. I bought it at Walmarts for $26 for a 5 qt jug. Quite a bit cheaper than Cub oil. I've been using it 3-4 years since I had an oil leak that was getting expensive. The dealer fixed the leak last winter to the tune of $600 for a lift valve replacement.
Bob B.
/ Oil and Filter #4
Exotic fluids and filters are nothing but a rip off, and a total waste. I have a much cheaper Cub model, with the big Kohler twin (26 hp), and a transmission with no serviceable filter. I've run a conventional 15w40 diesel oil in both the engine, and transmission since nearly new. Engine oil gets changed twice a year, tranny once. Oil filter of choice..Purolator Classic, $3.27 at Walmart.... Oil, Delvac 1300, $12.47 a gallon at Walmart.
Mower turned 10 years old this month, hour meter stands at 1,006 hrs., runs fine, no leaks or drips from engine or tranny.
/ Oil and Filter #5
Toyota Corolla filter fits most Kohler motors Z418 is the reference number here in Australia
Use genuine Cub filter on the Hydro , or look up BDU/Hydrogear in the USA and see what they recommend
Oil for engine 10w/40 good quality , Oil for Hydro 15w/50 Synthetic is the best and extends the change intervals
Have been using these for 17 years on a HDS 2155 and a GT2550
Oz
/ Oil and Filter #7
AC Delco PF53 cross to the kohler 12-050-02 inside and out with standard 10 W 30 "SALE" oil
on a 2005 cub LT1050 26 hp
Caterpillar D4 Dozer Parts and Service Manuals (A63117)
Caterpillar D4...
Deere 333E (A60462)
Deere 333E (A60462)
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
Caterpillar 950B Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 950B...
2007 FREIGHTLINER CL112 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59912)
2007 FREIGHTLINER...
2009 Toyota Highlander SUV (A61574)
2009 Toyota...
