Oil and Filter
/ Oil and Filter #1
timkins
Fishers, NY
Cub Cadet Model 2542
Just changed the oil and filter plus the transmission filter on a 20hp Kohler Cub model 2542. Its ridiculous what the dealer charges for 1 quart of hydrostatic transmission fluid. What I am looking for is cross reference numbers for the Oil Filter, Transmission Filter and transmission fluid for the 2542. Anybody that has the appropriate cross referenced numbers so I can go to a NAPA store would be appreciated.
/ Oil and Filter #3
An equivalent oil is 20W50. If you are using Drive System Plus synthetic oil, as I do, I use Mobil 1 20W50. I bought it at Walmarts for $26 for a 5 qt jug. Quite a bit cheaper than Cub oil. I've been using it 3-4 years since I had an oil leak that was getting expensive. The dealer fixed the leak last winter to the tune of $600 for a lift valve replacement.
Bob B.
/ Oil and Filter #4
Exotic fluids and filters are nothing but a rip off, and a total waste. I have a much cheaper Cub model, with the big Kohler twin (26 hp), and a transmission with no serviceable filter. I've run a conventional 15w40 diesel oil in both the engine, and transmission since nearly new. Engine oil gets changed twice a year, tranny once. Oil filter of choice..Purolator Classic, $3.27 at Walmart.... Oil, Delvac 1300, $12.47 a gallon at Walmart.
Mower turned 10 years old this month, hour meter stands at 1,006 hrs., runs fine, no leaks or drips from engine or tranny.
/ Oil and Filter #5
Toyota Corolla filter fits most Kohler motors Z418 is the reference number here in Australia
Use genuine Cub filter on the Hydro , or look up BDU/Hydrogear in the USA and see what they recommend
Oil for engine 10w/40 good quality , Oil for Hydro 15w/50 Synthetic is the best and extends the change intervals
Have been using these for 17 years on a HDS 2155 and a GT2550
Oz
/ Oil and Filter #7
AC Delco PF53 cross to the kohler 12-050-02 inside and out with standard 10 W 30 "SALE" oil
on a 2005 cub LT1050 26 hp
2022 John Deere 5055E (A60462)
2022 John Deere...
2022 John Deere 616R Sprayer (A63111)
2022 John Deere...
Lot of 4 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
Harrell 6710 (A64119)
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
2022 EZ-GO ELITE...
