OH NO ! !
/ OH NO ! ! #1
Mrwurm
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
I was out in the garage the other day and I saw some melted snow under my tractor. A few days later it was still there. /w3tcompact/icons/hmm.gif Hmm, that should have evaporated by now. Uh Oh, on closer inspection its hydraulic fluid. It's dripping from the hydraulic filter, the frame, all over actually. I'm gonna do a closer inspection today. This will probably result in a warranty repair. No big deal except for the transporting part.
/ OH NO ! ! #2
Try tightening the filter and lines before you send it to the dealer.
/ OH NO ! ! #3
If you have recently changed the filter, make sure the old seal came off with the old filter. I had one stay on and then screwed the new one right on top of it. Sure glad I caught it before I had a more serious problem.
/ OH NO ! !
The filter has never been changed, only have 35 hours on the tractor. The last time I used the tractor was two weeks ago to clear snow off the driveway. Hydraulic action was slower than usual. I am pretty sure that was caused by the cold outdoor temp.
Also, there is hydraulic fluid dripping from the frame from the front of tractor all the way back to the bellhousing area.
/ OH NO ! ! #5
With fluid on the ground that far forward I would be checking the fittings around your power steering, or posibbly the hydro pump itself. Oil way back to bell housing was probably blown there by the fan.
/ OH NO ! ! #6
Could it be comming from one of your loader quick connects and running down the frame or axle then dripping? Probably not cause that be to easey. good luck,
Larry
/ OH NO ! ! #7
I would check all the fittings. On new machines when assembled, sometimes the mechanics miss a fitting or two. This happened to me on a new kubota lawn tractor. Several of the fittings were just hand tight.
/ OH NO ! !
Checked it out the other day and found that there is an oil cooler in front of the radiator. This little cooler is covered with oil and seems to be the source for the leak. I also found some drops of coolant hanging from the frame. Called the dealer yesterday and they picked up the tractor this morning for warranty repair. I hope I get it back before it snows. /w3tcompact/icons/smile.gif
/ OH NO ! ! #9
Mrwurm, You've gotten plenty of great advice already but I can come up with a sure fire solution that works for me...
Park it over grass, when it leaks enough, it'll kill the weeds.
Actually, I'll be building a barn soon and so right now I'm jealous of you guys storing your machines' indoors.
Later, Kyle
/ OH NO ! !
Finally got my tractor back from the dealer today. It's return was as mysterious as it's departure. After my initial call, the dealer just showed up and took it. Two weeks later it shows up in my driveway. I guess they're not much for communicating. Anyway, I called the dealer and he said he replaced a ruptured hydraulic cooler and a split hose leading into it. He also fixed a leaky coolant petcock valve. And the best news: No charge for repairs or transportation!
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
2016 Hyundai Box Trailer (A62613)
2016 Hyundai Box...
2015 Ford E-350 Shuttle Bus (A64556)
2015 Ford E-350...
30x57 Welding Table (A65640)
30x57 Welding...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2013 International WorkStar 7400 Crane Truck, VIN # 1HTWGAAR0DJ296617 (A65563)
2013 International...
