Oh...No!!!
   / Oh...No!!! #21
Hey CTF, did you try using your differential lock?
   / Oh...No!!!
No, beacuse the dealer said to be careful using it (and I still don't understand what it is and how it works...:confused:...I guess I'll have to read the manual again...)
   / Oh...No!!! #23
hmmm, i use diff. lock quite a bit on lots of tractors, even on a BX24. It basically locks the rear end and all 4 tires (if in 4wd) to go only strait. I also have had the diff. lock get stuck on before too. You can not steer, even in 4wd, the front tires will just wear. So you have to just drive strait and wait for a "pop" sound, thats the diff. lock disengaging. If used under the rigtht cercumstaces, it will serve you well, it has saved my yanmar from getting stuck many times.:thumbsup:
   / Oh...No!!! #24
Hi
You might keep in mind that a tractor will get stuck way easier than you think even with 4 wheel drive-- and the differential locked....If you just begin to sense a problem stop immediately and back up, or spend some time getting un stuck :) The bigger the tractor the quicker it will stick itself...Tony
   / Oh...No!!!
Thanks, you really know your stuff for being the same age as me!!! :thumbsup:
   / Oh...No!!!
Hi
Yes, as soon as I got stuck I immediately stopped.
2012 KENWORTH T800(INOPERABLE) (A50854)
2012 KENWORTH...
Hotpoint DBL1550BALAD Dryer (A50860)
Hotpoint...
4 1/2 150G DRILL STEM 288 JOINTS (A50854)
4 1/2 150G DRILL...
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
2007 John Deere 7930 4WD Tractor (A50860)
2007 John Deere...
2005 OVERLAND TANK KILL TRAILER (A50854)
2005 OVERLAND TANK...
