Loader Oh man bad luck or design
/ Oh man bad luck or design #1
gusman2
STOW,MA
KUBOTA L3940HST BACKHOE
Broke left top bucket connection that holds top of piston to loader.
Had friend Come weld same. The metal it attaches too seems thin. Was almost done basket ball court and retaining wall project
/ Oh man bad luck or design #3
Wow...have never heard of a failure at this point...looks like it was a bad weld to start with?
Good looking project, know you are anxious to get it completed!
/ Oh man bad luck or design #4
Yep, very bad weld. Welder put all the metal on the bushing and very little on the metal bracket. Perhaps you should have gotten the welder to put another pass around the other bushing and even the other side of the FEL also.
/ Oh man bad luck or design #5
Do you think a welder was doing the work or a machine? If a machine wouldn't it stand to reason there are a lot more made just the same?
/ Oh man bad luck or design #6
Does look a tad thin to me also. Noticed the weld did not break the Bracket did.
This was a factory weld. My welder made it good as new. Thicker weld is this does not hold I will install plate to spread weight out
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
Suzuki King Quad 700 (A62613)
Suzuki King Quad...
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
