Offset reverse flow smoker
/ Offset reverse flow smoker #1
joeu235
Platinum Member
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
I've always wanted to make a smoker. It took a lot of hours but the first brisket made it worth it.
3/8 x 24 x 48 pipe and a sheet of 1/4 plate
/ Offset reverse flow smoker #2
The fact that you do the cutting freehand is impressive, definitely a talented craftsman
/ Offset reverse flow smoker #3
That was a great project and video. The brisket looks delicious!
/ Offset reverse flow smoker #4
I am inspired by your talented project. Now I am hungry.
hugs, Brandi
/ Offset reverse flow smoker #5
Now I want to build one. Nice Work !!!
/ Offset reverse flow smoker #6
If you want to build another one off your first prototype, I'll help you out by covering your materials for this one and come pick that one up so you can build v2.0. I think I could get some use out of that!
Brett
/ Offset reverse flow smoker #7
You need to install some counterweight on the back to help with opening that lid. A little high temp paint would look nice on it too.
/ Offset reverse flow smoker #8
OP... fanastic video. I was 'riveted'. Loved the part where the level was backlighted by the arc. Great editing. Learned a few tricks in quick fashion too. Thanks for posting!
/ Offset reverse flow smoker #9
Looks good. I have built a number of reverse flow smokers over the years.
The most useful feature I have added was automatic temperature control.
These are two of the methods I have used.
Thanks for the kind words.
I kept track of my labor hours and material cost as I built it. I think if I ever sold it or similar the price would have to be at least $2200.
I might paint it, but I see so much unpainted farm stuff from my grandfather built 50 years ago that has only surface rust I'm not sure it is worth it.
I installed a counterweight and opening is much easier.
/ Offset reverse flow smoker #11
Maybe a hi temp baked finish would be slick and I would probably give it a try just to 'finish' it but certainly not needed.
/ Offset reverse flow smoker #12
I like the unpainted look.
(4) Trail Quest 235/80R/16 Tires and Rims (A64047)
(4) Trail Quest...
2014 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2014 TROXELL 150...
Bush Hog 244-7QT Front End Loader (A64047)
Bush Hog 244-7QT...
2012 Mercedes-Benz 2500 Sprinter Van (A61573)
2012 Mercedes-Benz...
John Deere 155 Grader Blade (A64047)
John Deere 155...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
