Offset Finish Mower
/ Offset Finish Mower #1
CJBOTA
Salem, Ohio
Kubota B2620 & MX5100
Last year I started a small orchard ( 1500 ) trees. At this time I can mow the entire orchard with a standard finish mower. As the trees get larger I am going to want to reach under them and won't be able to get close to the tree because of the roll over bar. I was wondering if there is such a thing as an offset finish mower that would reach in further on one side.
Please don't question why I am using a finish mower instead of a brush hog. I like my orchard to look like a golf course, which I know is stupid but it's my orchard and that's the way I roll.
Anyway If anyone knows if or who makes an offset mower I would appreciate the input? Thanks.....cj from ohio
/ Offset Finish Mower #2
You could certainly get a flail mower with offset, there are even some where the offset is hydraulicly operated. Is the cut golf course quality? Well, maybe a public course...
/ Offset Finish Mower #3
Swisher makes a finish trail-mower that can be offset. Of course........ then you have to gas them up since they are not PTO powered.
/ Offset Finish Mower #5
/ Offset Finish Mower #6
How big an area are you mowing, how far apart are the trees, what is the capacity of your tractor?
I own an apple orchard. it has four stages of maturity. Each level of maturity is a different technical challenge.
Without much information, I would point you to a slewing flail mower, PTO driven, outfitted with finish hammers, sized for your tractor's weight and capacity.
/ Offset Finish Mower #7
/ Offset Finish Mower #8
Not sure if it will work for you but I bought a 7 ft Woods mower and swung it to one side with the tractor link arms. I can go maybe 18" under my trees.
/ Offset Finish Mower #9
Over the years there have been several offset mower designs with swing-away extensions for mowing in the tree row without having to feed the mower in and out between plants. Check out the mower page at Ochard Equipment . Scroll down to see a few examples. The big deal here is avoiding damage to tree trunks and the fruit, while reducing the bulk of ground cover foliage competing with the trees for nutrients. Another approach is using an orchard herbicide to clear a stripe at the tree row.
/ Offset Finish Mower #11
Take a look at this offset cutter...
It may be close to what you need.
Bush Hogョ SQ84T Multi-Spindle Rotary Cutter
/ Offset Finish Mower #12
Look at a Woods Mo80 it is kinda in between a finish mower and a rotary cutter.
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
1143 (A63745)
1143 (A63745)
2000 Chevrolet Astro Cargo Van (A64194)
2000 Chevrolet...
2020 CATERPILLER 326 EXCAVATOR (A65053)
2020 CATERPILLER...
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
