OFFSET BOBTACH
/ OFFSET BOBTACH #1
richmatz
bobcat s300
84" highflow snowblower
I need to offset my snow blower to one side or ther other so that I can blow closer to the egde of the road, with out going in the ditch. THe dork that made the road forgot that a shoulder would have been nice.... my thought was to buy a BOBTACH and cut off the pin connections that mount the bobtach to the boom of the Bobcat, then weld this to a new connection plate, might need something inbetween the modified bobtach and the plate so that it will all work out. the ideal thing would be to have the thing adjustable/slidable so that you can offset the blower to either side...
HELP!!!
/ OFFSET BOBTACH #2
A friend of mine has a tiller on his SSL and one side the motor hangs out and the other is flush with the machine. When working around walls and rescesses he had to offset it. We first put the quick tach plate offset with bolts but it was a pain. so we then took the plate and 2 sets of reciever tube and hitch tube and made a greasble slide out of it. then we put on a small cylinder to ofset it. works real good has about 18 inches of travel could have been more, we can add a longer cylinder later.
/ OFFSET BOBTACH #3
bobcat s300
HELP!!!
What about some form of side wing? Could give you 3-4 ft when extended. Saw a post here on TBN about one.
2013 Nissan Pathfinder SUV (A64557)
2013 Nissan...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
Texaco Gas Pump Yard Art (A64557)
Texaco Gas Pump...
2025 FABRIQUE VICTV714TA2 T/A  14FT ENCLOSED TRAILER (A67148)
2025 FABRIQUE...
JOHN DEERE LOADER MOUNT QT BALE SPEAR (A64278)
JOHN DEERE LOADER...
2014 Toyota Tundra Crew Cab Pickup Truck (A64194)
2014 Toyota Tundra...
