Off the Grid
/ Off the Grid #1
Bill Barrett
Platinum Member
midwest
Kubota L3130, Satoh G650, Case 580, Case 446
Anybody off the grid? hows it working for you?
Thanks Bill
/ Off the Grid #3
Hi Bill,
I've been off-grid since the late seventies and it works "ok" for us. If we used the amount of power that we do and were "on grid" we'd have very small utility bills. As it is, we average $150/month for propane which is our only utility source other than the sun.
Propane powers two fridges, with refrigeration one of the most difficult parts of living 'off-grid'. The propane also powers a 10KW generator that replenishes the battery bank during dark and stormy days. Also propane is the water heater, range and oven. We use two gallons per day if we don't run the generator for power and three gallons per day during the stormy months when we have to compensate for lack of sunlight.
Last year I began sending excess solar-supplied electricity to the refrigerators. I had to cease that project before I even could get a feel for what it'd save in propane because the particular propane/AC refrigerators I have recently had a recall because of defective electric heaters and tube welds at those heaters. So far Dometic hasn't released a "fix" and starting in April will be installing "band-aids" that prevent the problem from becoming a disaster but don't address the problem. You can read more about it here if you are interested: RV.Net Open Roads Forum: Dometic Refer Recall - Possible Fire Hazard -Update 2/13/07
Because of that problem I'm no longer sending any AC to the fridges, leaving them solely propane powered. Next time around I'll get the most efficient regular AC fridge I can find and make sure I have the photovoltaic panels and battery bank to support it. A decade ago standard refrigerators weren't nearly as energy efficient as those available now.
Lemme know any other questions you might have.
Phil
/ Off the Grid #5
Caver,
I have been researching a micro hydro system for about 2 years now and i think the time will be right within the next year to pull the trigger on this project. Especially since the my state ( Maryland) is going to raise of electricity rates 75% next year !!!
I have a flow of 150 gpm and a head of 55 ft. which after doing all the math equals out to right around 650KwH a month. Good enough to substantially decrease my bill and maybe even eliminate the bill all together... I can't wait to quit lining the pockets of others and start making my own power.,
/ Off the Grid
scesnick said:
Caver,
Sounds like a heck of a start. If you have the resource like it sounds you have, I think hydro is the best option.
/ Off the Grid #7
You may also want to study up on cogeneration gear. While not necessarily off-the-grid ready, this technology has been getting some press lately. I have no personal experience with this, but just by way of example this outfit has some cool stuff in the works:
Climate Energy
~paul
/ Off the Grid #9
scesnick said:
Caver,
The beauty of hydro is that it typically can run 24/7. If you go with a battery/inverter system and use the hydro to charge the batteries, they can be charging at low use times and store that energy for peak use times. DC is also much simpler with hydro as you don't have to regulate turbine RPM as closely as you do to generate a good 60HZ AC. With the right type inverter, once the batteries were peaked, any excess could be sent back into the grid to earn credits for the commercial power you use. Some solar systems I have seen go strictly net meter, using the grid as your battery. With sun, any power produced by the inverter that is not used by the home, is sold back to utility and meter spins backward. No sun and meter spins forward as you draw from the grid. Then the trick is to use less than you generate so the meter's net movement is backward. Being able to generate 24/7 would really help with this. By basing on DC and batteries or net meter, you can also incorporate solar into the system fairly easilly(but not cheaply:( to increase your power output... Sounds like an exciting project. Surew would be nice to get a check from the utility at the end of the month:)
Ron
/ Off the Grid #10
Our house is wired for living off the grid. We have a 12 kw diesel generator I imported from japan with a mitsubishi engine.
We have 8 trojan T105 batterys and a trace inverter for a backup
When the power goes out we just switch over
also a woodstove, propane stove, propane water heater, ect....
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
Freightliner Cascadia (A63689)
Freightliner...
2002 Ford Ranger Pickup Truck (A61573)
2002 Ford Ranger...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
