off road diesel
/ off road diesel #21
Kind of funny that some people always have issues with water in gas or fuel, and others don't. Must be some peoples storage containers are not as air tight as they should be.
I have never had issues with contaminates in my overhead diesel storage tank even after storing fuel for several years between refills. But part of it may be due to the fact I use a 3 psi pressure cap. So it reduced the amount of air exchange.
/ off road diesel #22
You must have a special kind of luck. Fuel left outside like that just about anywhere else would trash todays injectors quick
No, not at all. Mobile and modular homes and structures without a basement with oil-fired furnaces, boilers, and water heaters almost always store heating oil or kerosene outdoors. I'm a licensed master oil burner technician and had many accounts with outdoor tanks. Those tanks last for years and are never cleaned - more fuel is added. These tanks might be in service for more than 30 years. The burners had nozzles as fine as .50 GPH @ 100 PSI, and those small orifice nozzles can clog easily - easier than diesel injectors which operate at 1,800+ PSI.
Unlike gasoline, heating oil and kerosene have long shelf life. I've run my 1999 John Deere 790 compact tractor exclusively on a 275 gallon fuel tank since new and at almost 1,900 hours it's still on its original injectors. There is never any water in the tractor's fuel filter bowl to drain.
Another interesting fact is that in Maine (and probably most other states where #2 heating oil is a common fuel for heating) heating oil is now also ultra low sulfur - same product as diesel fuel.
I always wait a day after a fuel delivery before pumping any fuel - delivery trucks pump really fast and if there's any sediment in the tank it can be stirred up during a delivery.
/ off road diesel #23
I have never seen results like that around MY area. Peeps always be adding additives and biocides, etc. Fuel sucks around here.
/ off road diesel #24
We have had fuel quality problems a couple of times. It has always been a pain as when it's first found it's already in several systems. Now as soon as we even suspect that a load of fuel may have the slightest chance of having something all the tanks involved get a dose of biocide and we keep a close eye on filters, both tanks and equipment.
/ off road diesel #25
Todays HPCR injectors have tolerances so tight the molecule size difference between diesel fuel and water will ruin them; then there's the steam factor that water presents in new HPCR style injectors. (18,000-24,000 psi)
Shoot, those old diesel engines would run on practically anything that flows through a pipe
/ off road diesel #26
Exactly.
You could get away with crap fuel on 20+ year old diesels.
Not any more….
/ off road diesel #27
I would never fuel up from anything other than a high volume fuel station if running a CP3 or CP4 HPFP.
On the other hand, I would have no problem filling up a mechanical based fuel pump with bulk storage tanks.
We don't have high taxes here on fuel so the dollar difference to supply tax free fuel is very minimal. So everyone just buys regular ol diesel for everything. I have never seen dyed diesel in my life. If that tells you anything.
/ off road diesel #28
When I was working in the Evanston area of Wyoming several decades ago I saw several thousand gallons of off road labeled #2.
/ off road diesel #29
I have both local. The station is the only one even close to the house that sells Red off-Rd.. Two pump station for the Red Dye. Around the back side of the building. It's a large Chevron with Gas and 8-10 pumps.
Only use Diesel in the mowing season and hardly ever do I see people pumping the red off-Rd.. Hardly ever or basically never see a Tractor or farm equipment fueling up with it, Always filling 5 Gal. cans. Yellow ones for a while.
Couple Yrs. back my Red 5 gal gas can they wouldn't let me fill it with off rd. Diesel. INKY!! Prices was super high and just to save the almighty dollar people would fill the cans and then use it the Pickups, cars Etc.. The sales was way up IMO.. My Yanmar doesn't use much fuel and I noticed that you never or rarely ever see anyone filling Off Rd. diesel. Esp. now with lower prices. It has crossed my mind that it has to set in the storage tanks for a long while. Not seeing it being used very much I'll pay the couple extra dollars just to be safe.
/ off road diesel #30
My off road diesel fuel stop has guys in line waiting to fill tractors and tanks mounted in trucks. I’m in a very heavy AG area.
Some of those tractors running on red dye are $250,000-$500,000 tractors, too.
I’ve only had ONE injector related failure and it was using old fuel from a 300G storage tank.
No offense, but I probably use 100 times as much diesel fuel as the average TBN guy per month, so my sampling size is a LOT larger. It’s very common to use 100+ gallons in one long day of raking, baling & stacking.
My diesel fuel bill for August alone was $1,200.
1611 (A57192)
1611 (A57192)
2019 CATERPILLAR 259D3 SKID STEER (A62129)
2019 CATERPILLAR...
2019 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60352)
2019 Ford F-550...
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
2019 John Deere 460E Articulated Dump Truck (A60352)
2019 John Deere...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
