Loader Odd squeak from front (axle?) with a full bucket of gravel - kubota 3400 - problem?
   / Odd squeak from front (axle?) with a full bucket of gravel - kubota 3400 - problem? #41
Remember that there is oil to check at each wheel, independant of the main (center) axle. There should be at least 2 plugs, possibly 3. One for draining, one for filling (fill to plug), and maybe a middle one for a fill level if there are 3 plugs.
   / Odd squeak from front (axle?) with a full bucket of gravel - kubota 3400 - problem? #42
I dont think the smaller Kubs are set up this way [mine arent]. Their wheel gears feed from the main.
larry
   / Odd squeak from front (axle?) with a full bucket of gravel - kubota 3400 - problem? #43
If I recall right, the L3400 has a fill plug, a check plug, and two drain plugs. The oil will "settle" when you drain and refill, so checking again after some use will mean a bit more oil to go in.
   / Odd squeak from front (axle?) with a full bucket of gravel - kubota 3400 - problem? #44
larry
My mistake, all of my various size 4wd tractors that I've had used this setup.:confused3:
UNUSED FUTURE MINI PALLET FORKS (A57193)
UNUSED FUTURE MINI...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2019 KUBOTA RTV X1140 (A57192)
2019 KUBOTA RTV...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
Hose Reel (A55758)
Hose Reel (A55758)
