Loader Odd squeak from front (axle?) with a full bucket of gravel - kubota 3400 - problem?
   / Odd squeak from front (axle?) with a full bucket of gravel - kubota 3400 - problem? #41
Remember that there is oil to check at each wheel, independant of the main (center) axle. There should be at least 2 plugs, possibly 3. One for draining, one for filling (fill to plug), and maybe a middle one for a fill level if there are 3 plugs.
   / Odd squeak from front (axle?) with a full bucket of gravel - kubota 3400 - problem? #42
I dont think the smaller Kubs are set up this way [mine arent]. Their wheel gears feed from the main.
larry
   / Odd squeak from front (axle?) with a full bucket of gravel - kubota 3400 - problem? #43
If I recall right, the L3400 has a fill plug, a check plug, and two drain plugs. The oil will "settle" when you drain and refill, so checking again after some use will mean a bit more oil to go in.
   / Odd squeak from front (axle?) with a full bucket of gravel - kubota 3400 - problem? #44
larry
My mistake, all of my various size 4wd tractors that I've had used this setup.:confused3:
Pallet of 3' LED Lights (A56469)
Pallet of 3' LED...
2015 Peterbilt 567 (A55973)
2015 Peterbilt 567...
2015 8ft. S/A Utility Trailer (A55853)
2015 8ft. S/A...
2017 Ford F-150 Pickup Truck (A55852)
2017 Ford F-150...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
2007 Ford F750 (A55973)
2007 Ford F750...
