Loader Odd squeak from front (axle?) with a full bucket of gravel - kubota 3400 - problem?
   / Odd squeak from front (axle?) with a full bucket of gravel - kubota 3400 - problem? #41
Remember that there is oil to check at each wheel, independant of the main (center) axle. There should be at least 2 plugs, possibly 3. One for draining, one for filling (fill to plug), and maybe a middle one for a fill level if there are 3 plugs.
   / Odd squeak from front (axle?) with a full bucket of gravel - kubota 3400 - problem? #42
I dont think the smaller Kubs are set up this way [mine arent]. Their wheel gears feed from the main.
larry
   / Odd squeak from front (axle?) with a full bucket of gravel - kubota 3400 - problem? #43
If I recall right, the L3400 has a fill plug, a check plug, and two drain plugs. The oil will "settle" when you drain and refill, so checking again after some use will mean a bit more oil to go in.
   / Odd squeak from front (axle?) with a full bucket of gravel - kubota 3400 - problem? #44
larry
My mistake, all of my various size 4wd tractors that I've had used this setup.:confused3:
LANES PULL TYPE FERTILIZER SPREADER (A57192)
LANES PULL TYPE...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2019 International DuraStar 4300 2,000 Gallon Water Truck (A55852)
2019 International...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
1999 CATERPILLAR 963C CRAWLER LOADER (A52707)
1999 CATERPILLAR...
UNUSED RAYTREE RABC44 - 44" BRUSH CUTTER (A57193)
UNUSED RAYTREE...
