O-ring size for SAE #8 ORB
/ O-ring size for SAE #8 ORB #1
Mechanos
Roosterville, MO
JD 955/70A/7 TLB
I need to replace the o-rings on a couple of SAE #8 ORB fittings. Can someone tell me the correct dash number of the o-rings for these fittings?
Thanks... but I was looking for the size hoping I could pick some up locally.
/ O-ring size for SAE #8 ORB #4
Part # is 568-908. It is not a size found in your common o-ring kit and is 90 durometer, common o-ring kits are 70 durometer.
/ O-ring size for SAE #8 ORB #5
Is this not the same thing from Discount Hydraulic?
4000-08 4000-08 | Buna O-Ring for #8 SAE/ORB $0.40 $0.38
Use with SAE J514 Straight Thread (ORB) fittings
/ O-ring size for SAE #8 ORB #6
ARP 568 uniform dash no. is -908, inside diameter is 0.644 o-ring thickness of 0.087, hope this helps.
Yes... that is what I was looking for. There is a rubber company here in town that has just about every size of o-ring you can imagine. However, I ended up not needing the specific dimensions. Today, I found a local hydraulic adapter shop that has excellent prices. I was able to pick up some SAE #8 o-rings for ORB fittings for pennies.
master diesel generator (A64553)
master diesel...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
2018 Bell B30E 30 Ton Articulated Dump Truck (A64194)
2018 Bell B30E 30...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
