O-ring size for SAE #8 ORB
/ O-ring size for SAE #8 ORB #1
Mechanos
Roosterville, MO
JD 955/70A/7 TLB
I need to replace the o-rings on a couple of SAE #8 ORB fittings. Can someone tell me the correct dash number of the o-rings for these fittings?
Thanks... but I was looking for the size hoping I could pick some up locally.
/ O-ring size for SAE #8 ORB #4
Part # is 568-908. It is not a size found in your common o-ring kit and is 90 durometer, common o-ring kits are 70 durometer.
/ O-ring size for SAE #8 ORB #5
Is this not the same thing from Discount Hydraulic?
4000-08 4000-08 | Buna O-Ring for #8 SAE/ORB $0.40 $0.38
Use with SAE J514 Straight Thread (ORB) fittings
/ O-ring size for SAE #8 ORB #6
ARP 568 uniform dash no. is -908, inside diameter is 0.644 o-ring thickness of 0.087, hope this helps.
Yes... that is what I was looking for. There is a rubber company here in town that has just about every size of o-ring you can imagine. However, I ended up not needing the specific dimensions. Today, I found a local hydraulic adapter shop that has excellent prices. I was able to pick up some SAE #8 o-rings for ORB fittings for pennies.
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A67148)
2023 KENWORTH T680...
2014 Lincoln MKS Sedan (A64557)
2014 Lincoln MKS...
2025 LandHonor LHR-G209 Anchor Shackle Set (A64194)
2025 LandHonor...
2012 Ford F-450 4x4 Liftmoore 1640 4,000lb. Crane Service Truck (A64556)
2012 Ford F-450...
2015 Chevrolet Tahoe SUV (A64557)
2015 Chevrolet...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
