O-ring size for SAE #8 ORB
/ O-ring size for SAE #8 ORB #1
Mechanos
Roosterville, MO
JD 955/70A/7 TLB
I need to replace the o-rings on a couple of SAE #8 ORB fittings. Can someone tell me the correct dash number of the o-rings for these fittings?
Thanks... but I was looking for the size hoping I could pick some up locally.
/ O-ring size for SAE #8 ORB #4
Part # is 568-908. It is not a size found in your common o-ring kit and is 90 durometer, common o-ring kits are 70 durometer.
/ O-ring size for SAE #8 ORB #5
Is this not the same thing from Discount Hydraulic?
4000-08 4000-08 | Buna O-Ring for #8 SAE/ORB $0.40 $0.38
Use with SAE J514 Straight Thread (ORB) fittings
/ O-ring size for SAE #8 ORB #6
ARP 568 uniform dash no. is -908, inside diameter is 0.644 o-ring thickness of 0.087, hope this helps.
Yes... that is what I was looking for. There is a rubber company here in town that has just about every size of o-ring you can imagine. However, I ended up not needing the specific dimensions. Today, I found a local hydraulic adapter shop that has excellent prices. I was able to pick up some SAE #8 o-rings for ORB fittings for pennies.
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
USA KB057-48" HYD BRUSH CUTTER (A65053)
USA KB057-48" HYD...
2025 TEXAS PRIDE 14FT T/A DUMP TRAILER (A59914)
2025 TEXAS PRIDE...
JOHN DEERE 7420 TRACTOR (A64278)
JOHN DEERE 7420...
2015 FORD F350 XL SUPER DUTY BUCKET TRUCK (A63276)
2015 FORD F350 XL...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
