Mechanos
Veteran Member
I need to replace the o-rings on a couple of SAE #8 ORB fittings. Can someone tell me the correct dash number of the o-rings for these fittings?
Mechanos said:Thanks... but I was looking for the size hoping I could pick some up locally.
Part # is 568-908. It is not a size found in your common o-ring kit and is 90 durometer, common o-ring kits are 70 durometer.
ARP 568 uniform dash no. is -908, inside diameter is 0.644 o-ring thickness of 0.087, hope this helps.
