Nx6010 check engine light ?
/ Nx6010 check engine light ? #1
HK45
Bethlehem, Pa
Kioti nx6010 loader backhoe
I have a nx6010 cab. Is it normal for the check engine light to come on when it's cold out, but after about a min it goes out? Thanks
/ Nx6010 check engine light ? #2
Yes it is....make sure you treat the diesel for winter temperatures. What you have described normally happens if the fuel has trouble getting though the fuel filter. It will cause the fuel rail pressure to drop enough to light the CEL. Keep the diesel treated and the problem will go away.
Hope this helps...
I do treat the fuel, but maybe I need to do more.
/ Nx6010 check engine light ? #4
You running 15 40 oil or 5 40 in cold temp oil is real thick in sub 0 temps. I run 5 40 all year in my trucks and tractors. Oil pressure comes up quicker.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
Progressive Liquid Nitrogen Applicator (A66285)
Progressive Liquid...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
