3-Point Hitch NX5010 top link
/ NX5010 top link #1
Mimijacq
Kioti NX5010
I bought a used NX5010 with a cab. Top link is missing. Only rear implement I plan on using is a flail mower. Plan on going the tractor supply route to purchase an old fashioned manual top link. What length do you recommend I purchase?
Can I go with one that has an opening/closing range of 26”-18”?
I will not be utilizing any type of quick hitch assembly.
I have not bought the mower yet.
/ NX5010 top link #2
Hard to say….but why not hook up the mower and take a measurement?
/ NX5010 top link #4
Cool. Then buy one from the dealer at the same time….
Include it in your negotiation. 😉
/ NX5010 top link #5
I have an NX5010 and I had a manual top link from my old tractor that I replaced with a hydraulic top link.
I just measured it and it strokes from 21" to 32" between the end pins. It works great for all my implements but if I had a flail mower I would have to get a manual one for that so I could use the extra rear hydraulics for the mower.
I agree with Robin that you will probably have to size one specifically to the flail mower and hopefully you can get one that works with your other implements as well.
Fortunately, they are not very expensive.
Happy Day!
/ NX5010 top link #6
Tractors are expensive, top links are cheap. Last count I made, I have no less than 8 top links. A couple are cat II. The rest Cat I of various lengths.
It's not hard////
/ NX5010 top link #7
Could get add additional remotes if you are handy for a decent price.
/ NX5010 top link #8
I find it strange you buy a very expensive tractor then only plan on using a flail mower. But then you will find a need for a back blade, maybe a rototiller and so on. Hydraulic top links will come in handy because you can use it to lift the back of the implement higher to clear obstructions.
/ NX5010 top link #9
I bought and installed a FitRite hydraulic top link nine years ago. It allows you to adjust ground engagement implements from - just OK to absolutely perfect. AND all while your buns are firmly planted.
60" EXCAVATOR RAKE (A64279)
60" EXCAVATOR RAKE...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2004 Dodge Sprinter 2500 Cargo Van (A61573)
2004 Dodge...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2015 Nissan Sentra Sedan (A61574)
2015 Nissan Sentra...
